72 k10 flat knuckles?
I did some reading but I was only able to find that 73-87 had a flat knuckle for crossover steering, I posted some pictures of my 72 k10 passenger side knuckle hoping that you guys can help me identified whether this is the correct knuckle for crossover.
Grease Monkey
Re: 72 k10 flat knuckles?
That would be the one. You will need to take that knuckle off and you or a machine shop drill and tap for the steering arm.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
![]() Join Date: Aug 2008
It looks the same as my 73 axle.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
![]() Join Date: Mar 2007
That is the correct flat top knuckle for crossover steering.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
Thanks guys!
One last question, this flat knuckle is from a Dana 44 1972 1/2 ton 6 lug axle and I have a set of 1986 3/4 ton 8 lug axles from a suburban that I'm going to swap in, are the knuckles interchangable between a 1972 Dana 44 1/2 ton 6 lug axle and a 1986 10 bolt 3/4 ton 8 lug axle? Posted via Mobile Device |
I "think" that the knuckles will work but the hubs are different. I have a corp 10 bolt and nearly everything from the axle tub and out is the same as the dana 44. The center pumpkin is different and the brake banjo bolt is metric on the newer axle. Most other parts should swap.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#7 | |
![]() Join Date: Mar 2003
The knuckles are the same except that the tie rod taper on the 72 comes from the top and the 86 is from the bottom. So, use both the 72 knuckles. Everything after that will bolt on. So, you are keeping the 10 bolt front? |
71 thru 77 have the pass side flat top knuckle. None of the 10 bolts that i ever saw had the pass side flat top. Pre 71 have a flat top too, but are drum brakes and the knuckle is different. Watch which way the TRE tapper is machined into the knuckle. Some are from the top, some are from the bottom.
Get your machinist to mill the top flat and drill and tap the mirror image of the pattern thats in the driver side.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
