Old 02-06-2012, 09:26 PM   #1
76stepsidechevy
single cardan front shaft?
Did any square body ever come with a single cardan front shaft? I just put in some 6" lift springs and the angles arent right to work with the cv shaft now. I know I could cut and rotate the steering knuckles but I'd rather not. The angles look like they might be ok with a standard single cardan shaft but I'll have to check with an angle finder. Im not wheeling the truck hard if at all just using 4 wheel if it snows bad. I can deal with some small vibrations in 4 wheel but not the clunking and banging a cv shaft makes when the pinion isn't pointed straight at the t case.
76stepsidechevy is offline   Reply With Quote
Old 02-06-2012, 10:01 PM   #2
Mike C
Mike C's Avatar
Re: single cardan front shaft?
My '86 K30 454 SM465/205 has a single cardan shaft.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-06-2012, 10:07 PM   #3
76stepsidechevy
Excellent, Ive got the 465/205 as well, maybe its as simple as hitting the junkyard and grabbing a front shaft from a newer truck.
