02-07-2012, 06:28 PM | #1 |
Best rust/frozen bolt fixer concoction
In the next two weeks I plan on installing my lowering kit on my 68. What has proven to be the best concoction to soak those rusty bolts to help them break free?
02-07-2012, 06:35 PM | #2 |
VA72C10
Re: Best rust/frozen bolt fixer concoction
I've just always used PB blaster since I found it. Spray on top and under a day or so ahead of time then again just before trying. If they're hard to get off after that I try heat if I have it...if not, I use an impact gun and wring them off (break the bolt) or use a breaker bar with a cheater if no air...
Looking for a 67-72 swb or blazer project in or around VA. |
02-07-2012, 06:37 PM | #3 | |
02-07-2012, 07:29 PM | #4 |
Equal opportunity joke ofender
PB Blaster x3
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
02-07-2012, 07:32 PM | #5 |
The Niner
PB Blaster X4
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-07-2012, 07:34 PM | #6 |
Garage wrench
PB Blaster is good but i've had better luck with a product made by Seafoam called Deep Creep, it works quite well.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
02-07-2012, 08:28 PM | #7 |
Kroil beats the brakes off the rest of the stuff hands down.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
02-07-2012, 08:32 PM | #8 |
Kroll is the best- also the most expensive......
02-07-2012, 08:35 PM | #9 |
I've just sarted using the Seafoam Deep Creep and am having decent results.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
02-07-2012, 08:35 PM | #10 |
Heat / torch works very well just use it safely
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
02-07-2012, 08:50 PM | #11 |
all of the above will work, especially if you start soaking them now.
02-07-2012, 09:02 PM | #12 |
Man of Mini-Talents
I just picked up a can of stuff from the makers of WD40 that is specifically for breaking loose bolts. I went to their website because I remember the name of it, but it must be new enough they haven't updated their site. Anyway I bought it because WD40 has a good reputation, but also because they have this nifty spray can:
I hate trying to stick the straw back under the tape. I'll let you know how it works in a couple of days.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-07-2012, 09:10 PM | #13 |
No mixture will do what this can...
If PB can't handle it this will. |
02-07-2012, 09:28 PM | #14 |
I am a Referee of life.
PB Blaster,Kroil,or the Deep Creep gets my vote.I used a 24 in breaker bar and a regular one for a back up.I had to work the socket in and then the breaker bar and put it together inside the spring.Once I got it started moving I switched to a quality long handled ratchet so I didn't have to reposition every 1/8 th turn.My luck went 50/50 I broke 2 and managed to get 2 loose.This is on the rear.I sprayed P B on them for about 3-4 days before I started.I went to the "Automotive Fasteners" here and bought all new grade 8 bolts to go back together with.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-07-2012, 10:19 PM | #15 |
idk if any of you have used it before, but i work in aviation and we use mouse milk. a company called aircraft spruce should have it, it is amazing, far more superior to pb blaster or wd 40. kroil is pretty good, but even my dad who used to be a gunsmith used mouse milk. thats the name of the stuff.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
02-07-2012, 10:32 PM | #16 |
I use PB and hit it a few times with a hammer
02-07-2012, 10:39 PM | #17 |
Kroil is the best I found also
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
02-07-2012, 10:56 PM | #18 |
Vintage 4x4s
Kroil, liquid wrench, are better than PB.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-07-2012, 11:21 PM | #19 | |
That ain't nothin'. This is somethin'. |
02-07-2012, 11:33 PM | #20 |
Restoring it $200 at a time...
Kroil products. Every one of our maintenance guys has 1-2 cans on his tool cart.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
02-08-2012, 04:11 AM | #21 |
Devil's in the Details
Kroil is what I use. Last year I finally broke down and ordered a whole case of the AeroKroil. It'll be enough to last me a decade probably.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
02-08-2012, 05:44 AM | #22 |
Kroil is the best I have used.
My old neighbor gave me a can because I was always working on my rusty trucks. Unfortunately, he moved and my can is getting low. Now I only use the Kroil on my toughest stuff. Liquid Wrench & PB Blaster for the regular stuff. Anyone know where to purchase Kroil? Haven't seen it in the auto parts stores or hardware stores. |
02-08-2012, 07:05 AM | #23 |
I'm partial to Kroil as well.
I just did a quick search and found this: http://www.kanolabs.com/google/ 2 cans for 12 dollars seems like a deal to me........and WELL worth it. Eastwood, Aircraft Spruce, and Wicks Aircraft Supply (among others) also sell it.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
02-08-2012, 08:14 AM | #24 |
Sisyphus was my mentor!
I second RedNeck. I have yet to see a bolt that presoaked in whatever your favorite penetrant is & then hit with a good hot torch not come out...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 02-08-2012 at 08:51 AM. Reason: Spelling & this is post 900 for me! |
02-08-2012, 08:15 AM | #25 |
Where can you just "buy" Kroil...as in walk into a store,give them money,and walk out with it?
