chevy 4 speed transfer case addaption
i am hopefully getting a 73-87 k20 longbed frame and axles this spring. i have a heavy duty 4 speed transmission with the grany low gear, now i am wondering if those transmissions have a port where a transfer case can be bolted on to convert into a 4x4? this setup is destined to have a 350 smallblock with a 67 chevy cab on it with a flatbed. anyone that could help me out , it would be appreciated.
Re: chevy 4 speed transfer case addaption
Is the trans a SM465? or Something else?
Not sure if it is a sm465,shifter is one piece with tranny, is there a way of identifying it?
Posted via Mobile Device |
http://www.novak-adapt.com/knowledge/sm465.htm
Here is all the info you need for a sm465. If you need to convert it to a 4wd set up they should have everything you need or can point you in the right direction. It should need a differnt output shaft i personally have not priced one but to be honest you could probaly get a sm465 with correct 4wd extension housing and shaft way cheaper from the junkyard. Hope this helps |
yes every little bit helps. i had a chance to look at my tranny today and in one of the number codes on the casting it had 465 in the begining of one of the number codes. so i am hoping it is a SM465
![]() Join Date: Mar 2011
the sm465 is the commonly used chevy manual trans mission. do you know what it came out of ?? if it has a tail housing with a yoke its out of a 2wd it can be changed for a 4wd but its a little work, not too bad tho depending on your skill level. If you want a 4 speed it might be easier to just get one out of a 4wd, there pretty common. depending on your axle gearing and tire size you might want to go with the NV4500, its a overdrive 5 speed, you will still have "granny" and you will get better highway MPG's. Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
i actually aquired the tranny when i bought my 84 chev it was in the bed , and been sitting on a skid in my back yard for a year now. i am not sure the year or make it came out of but it has no transfer case and just a yoke with a short tail shaft housing.i am not worried about highway use or mpg it is supposed to be strictly an around town wheeler. i am trying to find a 3/4 ton chassie with axles {preferably 4:10 gears}.
