Old 02-08-2012, 08:13 PM   #1
dan04103
dan04103's Avatar
'71 Steering Issue...
Hey everyone I have a question that I can't seem to find in the search. I recently took a 4" lift off my truck and went to stock suspension. Not too long after my steering went really loose (scary loose at even 35MPH). Anyway ended up replacing both drag link ends as they were shot. I had also took out the rasied steering arm and putting that back to stock as well. I centered everything back up and turning is even right/left and had the truck aligned.
Now to my question. Why when I turn the steering wheel my front left end rises or drops on which way I turn it? Drag link issue? Is the pitman arm changed out when you put a lift on? Is this normal? Don't recall this happening when the lift was on the truck.
Cheers!
dan04103 is offline   Reply With Quote
Old 02-09-2012, 01:33 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: '71 Steering Issue...
Get some body to turn the wheel back and forth while you get under there and look. Look at everything from the rag joint to the TRE's.
Jack up one tire, grab the tire and move it left to right and up and down. Look for play.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-11-2012, 12:36 AM   #3
freakshow108
freakshow108's Avatar
I'm interested in what you come up with on the steering issues, I'm doing a four inch lift on mine and and would like to avoid any potential problems. Thanks
freakshow108 is offline   Reply With Quote
