Old 02-09-2012, 01:03 AM   #1
54chevytruck
54chevytruck's Avatar
need an alternative to granny 4-spd with transfer case
I have a 1954 chevy truck that has parts from many different vehicles in it. As far as i can tell, most of the drive line parts came out of a late 70s early 80s chevy truck(when i had to find a replacement for the brake master cylinder, a 79 chevy one was identical)
Currently it has a granny 4-spd with a transfer case married to the back. from my understanding of it, this transfer case was made to fit only a granny 4-spd.
I need something different. Either a different manual transmission or an automatic.
I just need some suggestions on something that works well that i can replace it with.
Will try to post pictures of it over the weekend
54chevytruck is offline   Reply With Quote
Old 02-09-2012, 01:07 AM   #2
54chevytruck
Re: need an alternative to granny 4-spd with transfer case
The transmission was used and abused before i got the truck and doesnt shift well to save its life
Old 02-09-2012, 01:21 AM   #3
onebadbowtie
onebadbowtie's Avatar
allot of guys a swapping to the NV4500 due to having overdrive and granny low. these are in the newer chevy trucks like 88 and up. dirtylarry has lots of info on the swap in a thread in this section
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 02-09-2012, 01:22 AM   #4
onebadbowtie
here it is.... http://www.67-72chevytrucks.com/vboa...d.php?t=431033
James
Old 02-09-2012, 09:46 AM   #5
You can find another 4spd for cheap. You don't really need overdrive if you don't travel distances on the interstates and want to drive over 65 mph. The 4spds are hard to hurt,unlike the newer o/d transmissions,which are costly to acquire.
Old 02-09-2012, 12:25 PM   #6
54chevytruck
right now, the setup i think i have(i need to look this weekend) is a Ranger overdrive bolted in front of the transmission with i think a SM465 and NP205(i looked at the pictures in the following links)
http://67-72chevytrucks.com/vboard/s...d.php?t=502224
http://www.high-impact.net/transmiss...roverdrive.htm
The overdrive unit whines like it is low on fluid when it is completely full, it vibrates the secondary shifter more than i think it should, the transmission was hurt pretty bad by the previos owner(he had a winston cup racecar engine in the truck and he would go pretty hard on this truck) and i dont know what condition the transfer case is in.
I am thinking of either converting it to an automatic with an overdrive or a 5spd manual with or without the Ranger O/D that is currently in it
I plan on driving this truck on the highway as well as offroad
any suggestions are appreciated
Old 02-09-2012, 12:56 PM   #7
coops714x4
coops714x4's Avatar
here is my 2 cents. IF you are gonna scrap the SM465-NP205 setup, just make the decision which you would rather have, automatic or a manual, if you want a manual go with the chevy or dodge NV4500, If you want a automatic go with the 700R- NP208 combo, both are good choices and can be fairly easy to find, tho they can be a bit pricey, both are pretty straight forward swaps. there are modifications and some fab work either way. I personally prefer the NV4500, that's what I'm putting in my 71 K20. Coop
1971 K20, Coop's beast (project)
1972 C30 wrecker, "Big Ernest" (SOLD)
1975 K5 Blazer (wife's toy) she got it in the divorce
2014 Street Glide Special
1983 K20 Big Block, auto (work horse)
coops714x4 is offline   Reply With Quote
Old 02-10-2012, 11:25 PM   #8
odog
odog's Avatar
Really look at the 205, they are VERY hard to hurt. They can be broken, but you have to almost try to do it. If you go with an auto, the 205's bolt up to about all of them with out much hassle.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 02-11-2012, 09:40 PM   #9
Mike C
Mike C's Avatar
Your gear splitter and SM465 is way cooler than any of the other options out there IMO. Just rebuild it all. That is also cheapest solution too most likely.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-11-2012, 11:04 PM   #10
54chevytruck
I was wring about the transfer case. i was looking at it today and it is an np208
