02-22-2012, 12:16 PM | #1 |
Intake bolts
Sorry for the novice question, but I'm new to rebuilding engines.
I freshened up my 350 a little while my truck is blown apart. When I put the intake back on I just torqued the bolts as the manual said. Later, I heard something about putting some kind of sealer or antisieze on them. I've got to pull one of them out to replace it with one that has the extra thread on top so I can brace my serp set up. 1) Do I need to pull them all out and put something on the treads? If so, what? 2) Do I pull them all out at once and retorque as the manual says or can I just pull one at a time and then retorque? BTW, the motor hasn't been run since I put the intake on. Thanks.
BRENT -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
02-22-2012, 12:28 PM | #2 |
Re: Intake bolts
You don't "need" anti-seize if your putting steel bolts into a steel cast block. You only "need" anti-seize if you have dissimilar metals like stainless fasteners into cast or stainless or steel into aluminum. That said it never hurts to use a little, I do. As for the sealer, the 4 inside fasteners on each side are open to the lifter valley and will eventually start weeping oil onto the manifold. You can simply pull them out one at a time, use a thread sealer like ARP or Permatex thread sealer (stay away from silicone for thread sealing) and re-torque them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-22-2012, 12:56 PM | #3 |
Re: Intake bolts
Great. Thanks for the info.
So, on the 4 inside bolts, do I need sealer and anti-seize or will the sealer do?
02-22-2012, 03:05 PM | #4 | ||
"I ain't nobody, dork."
Re: Intake bolts
I always use a little thread sealer on intake bolts. Especially the ones that are open to the lifter valley. If no sealant is used... oil can creep up the threads over time and slowly leak onto the manifold.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-22-2012, 03:06 PM | #5 |
Re: Intake bolts
there are bolts on the intake that need to have a good quality thread sealer applied or else you end up with oil leaks and puddles of oil on your nice clean intake
02-22-2012, 05:05 PM | #6 |
Re: Intake bolts
Yes, the engine oil has a tendency to seep around intake manifold threads, especially on older heads (threads in the head are corroded and worn). I use a combination of black RTV and new, quality USA made bolts (3/8-16 x 1''). Chinese made bolts tend to have smaller major thread diameter (0.3656 to 0.3666) - just few mills or so when you take calipers to them (0.3750 is max). While couple of mills does not sound too much it makes a difference between a 'dry' engine and a 'wet' intake! ARP bolts are always on the money - but prepare to pay $19 for a set of USA made bolts vs. $9 Chinese Commi made crap.
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
02-22-2012, 06:29 PM | #7 |
My Carbon Footprint
Re: Intake bolts
Don't know if it's a bbc thing or not but I put sealer on every intake bolt. I never have oil leak but certainly had coolant leak onto the intake.
02-22-2012, 07:08 PM | #8 |
Re: Intake bolts
Just so I'm sure. You don't put anti-seize on the bolts that you put the sealer on, right? Not sure how you could do both.
02-22-2012, 07:22 PM | #9 | |
Re: Intake bolts
//RF
02-22-2012, 10:45 PM | #10 |
My Carbon Footprint
Re: Intake bolts
Not anti-seize. Thread sealer or liquid thread tape. I use Prematex sealer.
02-23-2012, 12:24 AM | #11 |
60-66 Nut
Re: Intake bolts
Also if you are not using original intake bolts, be sure they are the correct length. There are a couple holes where too long of bolts will contact the pushrods.
02-23-2012, 05:14 PM | #12 | ||
Re: Intake bolts
Just cuz they're going through an aluminum intake don't mean t=you need antiseize. Just pllain ol' thread sealant is needed.
If you had aluminum heads... maybe a different story. Gary
02-23-2012, 06:32 PM | #13 |
*** That's interesting ***
Re: Intake bolts
Question...do Vortec heads (with vertical intake bolts) have the same issue? I don't remember...I never used any sealant on Vortec heads, but maybe I'm doing it wrong...
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
10-23-2015, 07:21 PM | #14 |
But Found Her 25yrs Later!
Re: Intake bolts
While I had my cab and front clip removed, I pressure washed my sbc engine, and then ran it for awhile to see if I could locate my leaks. I thought they were coming from the valve cover gaskets, but it's actually leaking around the intake manifold bolts. Can I just take the bolts out one at a time and do the sealer on the bolts and holes, or do I need to remove my intake manifold and start over?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-23-2015, 09:21 PM | #15 | ||
Re: Intake bolts
Take 'em out one at a time.
Gary
10-23-2015, 09:41 PM | #16 |
Re: Intake bolts
Thanks.
What sealer would you recommend?
10-24-2015, 06:50 PM | #17 | |
Re: Intake bolts
I did find this post:
11-28-2015, 05:08 PM | #18 |
Re: Intake bolts
I took the three out that were leaking. One at a time. Wiped them down and put the Permatex Aviation gooey brown stuff gooped on. Torqued them.
How long until it all sets up and I can start the engine and see if all is good?
11-29-2015, 03:58 PM | #19 |
Re: Intake bolts
"How long until it all sets up and I can start the engine and see if all is good? "
Over night will be sufficient. |
11-30-2015, 05:36 PM | #20 |
Re: Intake bolts
Ran it for a good 10-15 mins. Revved it up to 3000 rpm for a good duration. Not even a slight sign of oil leaking.
Thanks everyone.
