Old 02-23-2012, 12:41 AM   #1
lwilliam22
my first 50 model, nova front clip issues
http://67-72chevytrucks.com/vboard/a...1&d=1329971672
This my 50 chevy pickup first project bought it and a 52 together. this truck has a "rear steer" nova front clip in it. and im in need of some advice as to the length of my steering column and the location and attachment to the gear box
http://67-72chevytrucks.com/vboard/a...1&d=1329971847
as you can see in order to have a shot a lining the column with the gear box i had to cut another hole. and still have roughly 6"-7" from gear box to fire wall has any one used this front end and if so how did you situate the steering column? a straight shot to gear box with a universal joint? im worried this mispositions the steering wheel inside by moving it so far any suggestions thanks, ive been watching alot of builds nightly for at least year and love the knowledge and ideas shown on here Thanks
lwilliam22 is offline   Reply With Quote
Old 02-28-2012, 12:34 AM   #2
lwilliam22
Re: my first 50 model, nova front clip issues
Nothing from anyone? No pictures ? I know a lot of you know about the rear steer nova clips. But no one has ever seen one used? Is it bad to connect the steering column directly with box ?
Old 02-28-2012, 01:03 AM   #3
slick48
I have the same clip on my 48....I bought the truck with it on it and yeah same issue. I also had to cut a new hole to line it up and I used a wrag joint to connect the column. It looks like you need a shorter column.
slick48 is offline   Reply With Quote
Old 02-29-2012, 01:02 AM   #4
lwilliam22
Thanks i had just about given up. That steering column was just for mock up. Do you remember the length on your column? That's what I'm debating on also is the length
Old 02-29-2012, 02:16 AM   #5
slick48
Sorry man I don't remember the length and am not around my truck to measure it for you. I ran into this guys thread yesterday and if you click on the link below you will see how he lined up his column. Hope this helps
http://67-72chevytrucks.com/vboard/s...=445185&page=6
