Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 02-23-2012, 08:04 PM   #1
chevymotocross
chevymotocross's Avatar
Black paint: How to avoid and remove clearcoat scratches?
Now I know why black vehicles require special care! Had my truck repainted gloss black over the summer. Since then, I have washed it quite alot, waxed it a few times. Still looks great for Maaco paint but in the sunlight, you can see lots of light scratches in the clearcoat.
I wash the truck with a clean glove type piece, always make sure it's free of any dirt or particles. I dry with a clean chamois. I use Turtle Wax Wash/Wax soap. I wax occasional with Mother's SynWax and remove with a clean terry cloth.
From what I understand, a polisher must be used to remove the light scratches? I would prefer doing this by hand versus a machine.
After the polish do I wax? I think the waxing is what is giving my truck the light scratches?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-23-2012, 09:12 PM   #2
Southcity
Southcity's Avatar
Re: Black paint: How to avoid and remove clearcoat scratches?
I have a black truck too - if you go the machine polish route - add a nice coat of high quality non-abrasive Carnuba wax after that to protect. I try to stay away from waxes that have any abrasives in them (mild or not). Since that is a fairly new paint job you should not need to use any waxes that have abrasives - these are the one that say they remove fine scratches and swirl marks etc. It's not that they don't work but again - that is a new paint job and you should not need to go that aggressive.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 02-24-2012, 02:34 PM   #3
chevymotocross
Thanks southcity..... and Duel is an awesome movie!
Old 02-24-2012, 04:25 PM   #4
Southcity
Southcity's Avatar
glad to hear you're a fan of Duel - how bout some pics of your ride?
Old 02-24-2012, 04:38 PM   #5
chevymotocross
Old 02-24-2012, 04:40 PM   #6
Southcity
Southcity's Avatar
really nice truck - clean, love the stance and the wheels. It looks like there are lights behind the grill - did you do something custom?
Old 02-24-2012, 05:52 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
I have been driving black vehicles for many years. there are tricks to limiting the number of scratches in them. ALl paint has scratches, but black shows it more than others.
A rotary buffer is the best way to remove scratches in paint. You want one that has the capability to put on a large 9" pad and also the ca pability to rotate in slow speeds. I use the 3M Super Buff pads on my Makita buffer. I still use 3M "Finnessee-It" for my buffing compound, but the "Perfect-It" will work also. It just takes a little different approach to use it. (CAUTION, DO NOT overdo the buffing and handle the buffer lightly or you will rub through the paint) After buffing with a buffer you can put on a good sealant for the paint to keep dirt from filling the paint pores. I use a material from a company called Wizards, that does a really great job. Once the paint is clean and sealed, the keep it clean with a detail spray (once again mine comes from Wizards, because it beats Mequiars hands down)
When I wash the truck, I do not use a chamois to dry with, unless I have no choice. The leather tends to scratch the paint more than I like. I use really soft towels and I keep them out of any dirt. The picture attached is an old one, but that shine is still on my truck today.
Frank
piecesparts is offline   Reply With Quote
Old 02-24-2012, 09:37 PM   #8
Dustytrix
Clean --- truck thanks for the info
Dustytrix is offline   Reply With Quote
Old 02-25-2012, 11:05 AM   #9
piecesparts
I presently drive a new black truck daily. I worked over the factory paint before I put it on the road with the same materials that I use on my 84. This stuff keeps the paint clean and it is easy to clean up after a snow storm or rain. Check out the "Shinemaster" and the Mist-N-Shine" products in the following website. I thought it was goofy when I first tried it, but as I said before, this stuff kicks Mequiars bottle every time.
http://www.wizardsproducts.com/store...us&mode=update
Frank
Old 03-04-2012, 10:08 PM   #10
2ndstoryslam
2ndstoryslam's Avatar
If you are satisfied withthe polishing step. Put 3 coats (1 each night) of Wizards sealant. Allow each coat a full day to set. It really blows away wax. Too bad you are so far away, I could foam pad that ride to brilliant shine for low dollar cost.
2ndstoryslam is offline   Reply With Quote
Old 03-07-2012, 10:34 AM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great info guys.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
