Old 02-27-2012, 01:05 PM   #1
HEISEL
HEISEL's Avatar
short or long throw out bearing? please help!
Hi all. so im putting my 72 swb 4x4 back together and i'm not sure about what throw out bearing to use. When I disassembled the truck and took the old clutch out I thought it had a short t.o.b but my friend just replaced his and it wouldn't work. turns out it needed a long t.o.b. This morning i went to o'rellys and got an off the shelf kit. and it came with a short one. but my buddy is telling me not to use it. what is true? any help would be good. I have a 98 vortec 350 and im using the flywheel from that engine. The kit i got is a 12 1/2 clutch kit for a 1972. By the way its a 72 swb 4x4 350 (vortec) and a sm465 and np 205. thanks.
1972 k/10 4x4 swb
2011 camaro SS/RS M6
HEISEL is offline   Reply With Quote
Old 02-27-2012, 01:47 PM   #2
61K10
61K10's Avatar
Re: short or long throw out bearing? please help!
I would use what came with the kit. there are 2 type's of pressure plates--one has 3 fingers and usually uses a short TB and a diaphragm pressure plate that has a bunch of fingers that the TB rides on. has a longer TB. newer trucks might be different as i am going back a few years. test fit before installing trans--------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
sm465, throw out bearing, throwout bearing
