Old 03-01-2012, 09:25 PM   #1
deathlinx
deathlinx's Avatar
Turn Signal problem
ok this might be hard to follow but i will do my best.
1969 C10 396
ok turn signal lights and indicators work normal with headlights off, if i turn on my headlights my RH indicator light in the cluster comes on and stays on, therefore my right turn signal does not work i push up on rod and it does nothing, no flshing of indicator or light or even the fuse flasher, the left side continues to work as normal, turn the lights off and its all normal again.
i put in new headlight switch same thing happened, new bulbs, cleaned the connections, took the flappy wire thing off the cluster and cleaned it...im very baffled of what is happening.
if there is anyone that may be able to help it would be a great day!
1969 Chevy C10 396
deathlinx is offline   Reply With Quote
Old 03-01-2012, 09:28 PM   #2
Fldawg
Fldawg's Avatar
Re: Turn Signal problem
Sounds like a ground wire probelm, check all your grounds
Fldawg is offline   Reply With Quote
Old 03-01-2012, 11:36 PM   #3
Wrenchbender Ret
Agree. Your right front parking/turn light is not grounded.
Wrenchbender Ret is offline   Reply With Quote
Old 03-02-2012, 12:02 AM   #4
deathlinx
deathlinx's Avatar
having it not grounded would make it not work while headlights are on, but when they are off it would still work normal??
1969 Chevy C10 396
Old 03-02-2012, 12:21 AM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Correct. In short, it's because is back-feeding through the other filament to find a return path. Fix the ground and it will work.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 03-02-2012, 09:17 AM   #6
deathlinx
deathlinx's Avatar
ok thank you, i will check...will i be looking more at the signal light/ itself or in the cab behind the dash?
i dont think it would matter but i didnt mention at begining that its just the indicator in the dash cluster, the actual signal light itself does not come on nor work in any way when the headlights are on. ifRH blinker is on and i turn on my headlights, the signal light itself turns off and the dash indicator stays on constant
1969 Chevy C10 396
Old 03-04-2012, 08:57 PM   #7
deathlinx
deathlinx's Avatar
THANK YOU....i had a bad ground at the light bezel. got everything fixed and working properly
1969 Chevy C10 396
Old 03-30-2016, 11:46 PM   #8
tyson8432
Where exactly was the bad ground, I'm having the same issue?
tyson8432 is offline   Reply With Quote
Old 04-04-2016, 12:03 AM   #9
deathlinx
deathlinx's Avatar
the 2 screws at the light bezel, i took off bezel, cleaned up body and bezel and and put new screws in. they had gotten corroded. rememeber that these old trucks are big on ground..if something doesnt work...always check the ground...give it a quick hit with a wire brush and replace.
1969 Chevy C10 396
headlight, help me, turn signal
