03-13-2012, 04:15 PM | #1 |
i need help!
i have a 1985 chevy blazer 4x4 and im trying to convert it to a 2 wheel drive. i have a 79 chevy truck long bed that im using parts from such as the front and rear end. my questions are. 1. will it just bolt up. 2. where can i get a drive saft to use.
any info is wanted. |
03-13-2012, 10:24 PM | #2 |
Re: i need help!
I can't tell you if it will all bolt up, but somebody here should be able to help. You might have to drill a few holes for the trans crossmember. Once you get everything in place, you can either have a drive shaft made or find one in a wrecking yard and have it modified. You might be able to get away with shortening the drive shaft that's in the 79...I would try that first.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
03-14-2012, 01:38 AM | #3 |
Re: i need help!
see http://67-72chevytrucks.com/vboard/s...d.php?t=168231 for documentation of the same swap you describe.
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=511830 |
