05-04-2003, 11:46 PM | #1 |
its all about the +6 inches
Check out what I made today
no...not a mess...although i did make a small puddle of blood.
I made a metal glove box for the one ton. I followed someone's advice on here (can't remember who though) and removed the remains of the paper glove box and traced it out on some steel. Then took it to work and used a nibbler type cutter to cut it all out. Bend it up into the right shape, paint it black, mount it in and added a couple screws to hold the sides together. I tried moving it around a little to see if it was going to rattle or anything and it all looks good. But I was afraid all the crap I'll put in there will rattle so i cut out some 1/16 (or so) thick rubber and glued it in. Worked out pretty dang cool IMO. Then, while I was at the junk yard rippin another tilt out of a van, (which resides in the GMC now) I nabbed the glove box light assembly out of it. You can't really see it in the pic, but the orange-ish light reflecting on the black paint is from the bulb. Well worth the blood spent. (the real awsome part is the fact I have absolutly no $$ wrapped up in this mod...just my time which isn't worth too much) |
05-04-2003, 11:47 PM | #2 |
Oh, i installed these today too. The big one has been in the GMC for ever...but the little one was in the van that donated the tilt to the GMC.
The junk yard guy laughed when i showed him and told me to keep it...no charge. I love that yard. |
05-04-2003, 11:50 PM | #3 |
Good idea with the metal glove box, I may try to make one myself...
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
05-04-2003, 11:55 PM | #4 |
not a bad idea. I once made one of wood for my 72 bug where I installed a sweet stereo. I left the old POS in the stock location to fake out some of the crooks. Well one day someone opened the trunk and took the entire wood box. Great.....I just made the stereo and CDs easy to cary for the stupid thief. Oh well it was time for a chevy anyway
72 C10 SWB 02 Subaru WRX 95 Nissan 240SX |
05-05-2003, 12:50 AM | #5 |
Fabricate till you "puke"
I like that glovebox! Something else I need to do.....the registration is closepinned to the bottom of the dash crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-05-2003, 01:09 AM | #6 |
Now the others dig........
I made one as well out of some tin. It actually looks very similar to Longhornsmails, but I took it out when I started putting in my CD player, and it's sitting at my freinds place right now. Oh...and my truck is in san antonio.....acheing with a broken heart.....and acheing for a 350
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
05-05-2003, 01:27 AM | #7 |
Did you slide it in from the front? Or go up from under the dash?
05-05-2003, 03:34 AM | #8 |
Quit making gloveboxes and get that thing on the road
Just sitting here contemplating contemplation. |
05-05-2003, 03:50 AM | #9 |
i love summertime
i like those pedals, ive been planning on doing the same thing
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
05-05-2003, 02:29 PM | #10 | |
Re: Check out what I made today
And a puddle of your blood. . . So did ya make a template so when the rest of us want one, you can start pounding them out? |
05-05-2003, 11:46 PM | #11 |
supercheyenne, I slit it in through the front. It wasn't screwed together yet so it was still flexible. I would not even try to do this on an asembled A/C truck.
RaceDvl, I did not. As I was tighteneing the last screws I thought about it and bout kicked my sell in the tail pipe. All it takes though is a semi-good paper one to trace. Mine had 1/4 of the paper missin, so i just flipped it over and kept on tracing. |
05-06-2003, 12:28 AM | #12 |
Not a bad idea, i just bought a new cardboard box for my 72, But now that i have the old on I may think about haveing or making an Aluminium Diamond plated one. Nice and polished.
I see your line that holds up your door, Maybe the same idea with some small fine chain looking , Make it look like a tailgate.. It only takes one to start the ball roll'n!!!
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-06-2003, 05:40 AM | #13 |
Space Cadet
hey, that's super cool! what gauge of sheet did you use? I have some laying around that I could cut up and try that out, but it may be too thin (I'm guessing it's about 24gauge)...
05-06-2003, 10:04 AM | #14 |
I miss this truck.
And the best part is, you should get at LEAST an extra 5 H.P out of that high performance gas pedal. Hehe
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
05-06-2003, 12:37 PM | #15 |
Dude, that glove box is cool as hell. I'm going to do that myself. I have a new liner from Chevy Duty (non-ac). I'll use that instead of the old one (the old one is in bad shape).
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
05-07-2003, 12:06 AM | #16 |
I couldn't tell you what guage the metal is...I don't mess with sheet metal, I don't know the thicknesses.
It is thinner than the metal on your hood...I can say that. (hope it helped?) I should get more than 5 horses...I have 2 cool pedals...That should be 10 horses right? |
05-07-2003, 12:26 AM | #17 |
Good Idea, on th eglovebox, however you may have to use Tenactin to keep from getting athlete's pedal.(lol)
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
05-07-2003, 03:22 AM | #18 |
could you post a picture of the template (with measurements) that you used so that i could make one at work? My glovebox is long gone. That would be really cool. Thanks
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-07-2003, 09:02 PM | #19 |
Navel Inspector
LOL
Gotta love them feet. Reminds me of the days when I was riding in the back seat of my moms VW. She had those magnets they used to sell in the gumball machines along with the fuzzy feet stickers that we would as kids slap on any metal part of the dash/car.
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
05-08-2003, 11:53 PM | #20 | |
I kept no measurements, no template, and the cardboard one got pitched at the shop which would be long gone now. Really sorry. |
05-09-2003, 01:25 AM | #21 |
hey longhornmail
you do know sheet metal gauge sizes, you just don't realize it.
sheet metal is sized by american wire gauge. ex. 12 gauge wire is the same as 12 ga. sheet metal. 22 gauge wire is the same as 22 ga. sheet metal etc. (not to be a no it all or nothin, just f.y.i.) tony
i survived cancer and kidney stones, but my kids are killing me. |
05-09-2003, 01:27 AM | #22 |
LOL...I was hoping no one would say that...
I don't really know wire sizes either. Thick and thin... |
