Old 03-18-2012, 12:17 PM   #1
Red Rocket
Rotor replace
Trying to replace my front rotors but the hub wont split from the rotor any thoughts on ways trying to spilt them??
Red Rocket is offline   Reply With Quote
Old 03-18-2012, 01:42 PM   #2
skevac
Re: Rotor replace
Need to press all the wheel studs out first.
skevac is offline   Reply With Quote
Old 03-18-2012, 09:02 PM   #3
ghettoluxury
ghettoluxury's Avatar
Re: Rotor replace
Get a brass hammer and beat the studs out if you dont have access to a press. The rotor should fall right off then, if not give it a tap with the hammer.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 03-20-2012, 03:12 PM   #4
TDS-MN
Re: Rotor replace
Yup, need to remove wheel studs to get the two pieces to separate.
However, you can but rotors that have the hub 'carrier' attached already if you prefer. I do think it costs more to do it that way, and my local parts source did not have those on-hand, but could order them.
I ended up replacing rotors and re-installing my hub carrier.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
