Old 03-20-2012, 11:15 PM   #1
IHguy
swaping in a dana 60
I finally made time to work on my truck a little. Its an 83 diesel suburban that I took the 6.2 and auto tranny out and put a 93 6.5 turbo diesel and nv4500 tranny in. I pulled the full float 14 bolt outa the truck and re mounted the spring mounts and got that in. Now onto the front.... I traded a pretty much scrapped out, dont owe me nothing, old truck for what I believe to be a ford dana 60 front (ball joint) dont matter to me because I need a driverside axle to match my 93 drivetrain and this truck wont be a rockcrawler. So I think its a dana 60 and would like some help to verify that and help me with brake options and what not. I was told but its 4.10 gears so it convienently matches my rear axle too. Heres some pictures of the axle and the codes i found on it.
I believe it says 44 60F
35733 or 35783 have to look in the daylight again it was getting late on me and I set it ouside with the skid steer before i looked at the numbers closer.
and I pulled the calipers and rotors off the 93 just in case i could get them to work on this axle. One side of my ford axle has a braket and rotor but no caliper. also wondering if for now my stocker 1/2 ton ones on my burban will work with a braket just to get it moble for painting and stuff...
I sandblased the calipers quick and put a little paint on them to clean them up a little
Any help is much appreciated!!! Im very mechanically inclined but I work on farm equiptment for a living so Im learning the automotive stuff as I go especially on this project!
03 GMC Sonoma Crew Cab 5" trailmaster lift 33" tires bushwacker fender flares
83 Suburban/Avalanch project 6.5 turbo diesel nv4500
IHguy is offline   Reply With Quote
Old 03-20-2012, 11:39 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: swaping in a dana 60
It looks like a Dana 44 to me. Dana 60 should have studs on one side of the spring plate. If it is a 60, Ford changed to a ball joint in the later years. Not as strong as the kingpin in my opinion.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 03-20-2012, 11:56 PM   #3
mrdana60
looks like a 44 to me also. those axle shafts look small to me. you def can tell a 60 from a 44 by the axles and the ring and pin gears
mrdana60 is offline   Reply With Quote
Old 03-21-2012, 12:21 AM   #4
Redcap
That says "44 6CF". That is a Dana 44. Cover, casting, and axle tubes are too small to be a Dana 60.
Hope you didn't pay much for it.
Redcap is offline   Reply With Quote
Old 03-21-2012, 12:33 AM   #5
mrdana60
and it doesnt look to be a high pin either.
Old 03-21-2012, 08:30 AM   #6
^ Is that the same as high pinion? ^
I agree,that's definitely a Dana44. That's what the "44" stands for.
Old 03-21-2012, 09:29 AM   #7
mrdana60
yeah i believe there is dana 44 ford high pinion too but that doesnt look to be one.
Old 03-21-2012, 10:47 AM   #8
IHguy
Thanks, i didnt give hardly anything for it. i just wanted an axle that matched the driverside transfer case . what would my brake options be to try n stay cheap as i can and ill find a better axle down the road.thanks for identifying it!
Old 03-21-2012, 07:41 PM   #9
Mike C
Mike C's Avatar
Those aren't 60 calipers either. Take a pic of the spring mount. A GM 60 has studs on the passenger side on the inner side of the mount. Only uses 1 U-bolt on that side.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-21-2012, 08:59 PM   #10
Well,we've established it's a Dana44 and now the question is brakes. If you don't have any parts at hand to try to fit up,I think the easiest route would be locate the Ford parts and go with bot-on. GM parts may very well fit,but if you have to buy to try it's not worth the risk.
Old 03-21-2012, 09:02 PM   #11
mrdana60
i believe the ford dana 44 use a 5 bolt on spindle. and chevy use 6 bolt spindle. and i believe the spindals are different. i would run ford stuff. 8 lug pattern is the same and everything will work right for you.
Old 03-21-2012, 09:52 PM   #12
IHguy
Thanks, the big thing is at least i know its a 44. I think I may have better luck finding this stuff from some local horders since 60s are not so easy to find... Thanks again I really appreciate your help, this is a GREAT site!!!! wish I wouldve found it sooner!
