Axle swap and 4x4 conversion
Im wanting to swap out my axles and do a full conversion on my half ton 82 silverado im keeping my frame.Around here stuff is not easy to find but i found this 78 blazer set for 100 bucks theres a dana44 and a 12 bolt with 3:42 gears.The dana 44 doesnt have hub and doesnt have driver side shaft.I was thinking i want to take a gamble and for the parts missing i probably could find them around here.so i would buy them online aftermarket ir whatever hope there cheap.What you guys suggest.
1982 chevy silverado It's all about original guys original let me say again original. ![]() |
Re: Axle swap and 4x4 conversion
It would be easier to find a 4x4 frame and go from there, unless you are going to fabricate your front spring hangars. The only reason my friend started converting the 63 chevy I bought from him to 4x4 is because those years are hard to find in 4wd where we live.
Do you know why the front is missing the driver side shaft and the other parts? Were they used to fix another axle or did the PO break them?
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
#3 | |
The swap is not super hard I. Did it in a week just took the dog house and bumper off had all perches and spring mounds ready before I started had axle and springs mounted up its hard if u don't have lift and right tools
1977 k20 frame with 85 cab and hopefully 6.5 diesel. 1981 c20 long box 250 3 on the tree daily driver. 1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8. ![]() 1984 c30 crew cab dually 6.2diesel next project only 18 and finshed 5 projects started when i was |
