Old 03-21-2012, 09:35 AM   #1
Mutt65
Talking Tranny question
So my truck has sat for the last 20 years with minimal use. I am now driving it daily and figuring out what needs to be fixed and replaced. I've got a question about the amount of play the shift stick should have. I know it's a little off but I wonder if that's typical. The engine and tranny are from a camino and were put on back in the 80s. 4 on the floor, reverse and second are right next to the dash and first and third are right on the bench. I've noticed second seems to be getting a little further away. I've looked at the linkage and it looks like it is missing some washers where the linkage hits the transmission. It also likes to get stuck in an undefined middle area where I can't tell what gear it's in. Any tips or advice on what to do to fix it?
I don't have a camera right now or I would post pics. Thanks for any help
65 c20 fleet sbw lwb 307 olds-Color Rust, white household latex paint, black primer, grey primer and rust
She aint fast, But she moves forward with great dedication, that's about it, also doesn't stop either
Mutt65 is offline   Reply With Quote
Old 03-21-2012, 10:10 AM   #2
padresag
Re: Tranny question
what trans is it? 1 & 3 up. reverse , second and 4th down is what the orig 4 spd gives you.
what is a camino. what you seem to be describing is a 3 spd with an aftermarket shifter on it.
ron
padresag is offline   Reply With Quote
Old 03-21-2012, 10:15 AM   #3
Mutt65
Re: Tranny question
It was moved from the tree to the floor when the 1971 el camino 307 was dropped in. I'm not sure what tranny it is or how to tell. Reverse is in top left, 1st is bottom left, top right is 2nd bottom right 3rd, first gear is a granny gear. Any tips on discovering the type of tranny
Old 03-21-2012, 10:37 AM   #4
padresag
Re: Tranny question
then it is only 3 on floor and you don't have a granny gear.
if you have slop in the linkage , tighten it up. it is tough to advise on what you don't reallly know what you have or what the lingkage looks like
ron
Old 03-21-2012, 10:55 AM   #5
1963c-10
1963c-10's Avatar
Re: Tranny question
Sounds like a 3 speed to me. Reverse is forward right, 1st is rear left, 2nd is forward right and 3rd is rear right. Should be a "H" shift pattern. 3 speed would most likely be mc-318 muncie or saginaw. Borg warner also had a t-16 HD 3speed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-21-2012, 12:06 PM   #6
padresag
Re: Tranny question
wouldn't reverse be forward left?
it is more than likely the linkage that is the problem
ron
Old 03-21-2012, 12:09 PM   #7
Mutt65
Re: Tranny question
Ive always been told granny was the first gear on this tranny how do you know it's not?
Old 03-21-2012, 12:10 PM   #8
Mutt65
Re: Tranny question
It is h patterned
R2
13
Old 03-21-2012, 12:13 PM   #9
Mutt65
Re: Tranny question
But the general issue of extra play should be fixed by replacing the linkage then? Not an issue with the tranny itself?
Old 03-21-2012, 12:21 PM   #10
padresag
Re: Tranny question
it is an aftermarket shifter; there are cheap ones and there are good ones and everything wears. have you gotten under there to check what the linkage look like. is everything tight or is it sloppy?
now do you know what a granny gear is and what it's purpose is? I can answer it, but I want to see if you know?
ron
Old 03-21-2012, 02:33 PM   #11
Mutt65
Re: Tranny question
For applying a whole lot of torque and no speed. Moving heavy loads typically.
The holes on the shifter that hook to the pins in the transmission is not round it looks like it was drilled but it could be wear on both sides.
Old 03-21-2012, 02:45 PM   #12
padresag
Re: Tranny question
the granny gear in trucks is usually around about a 7:1 ratio. it is usually the 1st gear in a 4 speed trans(that is 4 gears forward). after that the gearing in 2nd is equivalent to 1st gear in a 3 speed, perhaps 3:3 ratio , equivalent to what you have in your 3 speed(3 gears forward.
so if the holes in you shifter are oval, that means wear and more than likely the rods that fit in them are more than likely worn also. that means slop in the linkage. so you can either take the linkage apart and build up all that wear and machine it back to size or go and buy another shifter. that wasn't so difficult was it?
ron
Old 03-21-2012, 02:48 PM   #13
Mutt65
Re: Tranny question
I thought it might of been a modification. Thanks for the help. I'm still learning about this stuff. Ironically this was my grandfathers truck and his name is Ron.
Old 03-21-2012, 03:07 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Tranny question
For clarifity, this is what is referred to as a “granny” transmission. It has an extremely low first gear ratio that runs out around 5 mph and is great for pulling very heavy loads slowly, to get moving.
They are easy to identify and the shifter stick will come out in the middle of the floor, and look like this:
If you have a typical 3 speed manual transmission it will have two shift levers on the side cover. If it is a passenger car 4 speed it will have two shift levers on the side cover, and another lever for reverse on the tailhousing as shown in this picture. This is a display of different brands of 4 speed transmissions:
If you have an aftermarket floor shift conversion kit the stick will poke through the floor on the driver’s side of the transmission, not in the center of the floor. A 3 speed transmission will have two levers hanging out the bottom of the shifter. A 4 speed will have 3 levers:
Here’s a layout showing the 4 speed on the left:
Aftermarket shifters come in all quality levels and most aren't very good. It what you have is a cheap model and worn out, it may be time to replace it with something better, assuming you want to keep this type of shifter and transmission.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-21-2012, 03:32 PM   #15
Mutt65
Re: Tranny question
The shifter sticks up and angles back towards the seat. The shifter comes out in the center of the hump and the coonections come out on the driver side of the trans
Old 03-21-2012, 03:50 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Tranny question
wow, then it might be some kind of factory shifter. I had a Pontiac 4 speed with a factory shifter and it mounted on the passenger side of the tailhousing. It was the only one I'd ever seen like that, and it did mount the shifter right in the middle. Here's a very poor photo taken off a video tape. It would be interesting to know if your shifter looks something like this:
The linkage on this unit was very tight, but the shifter head and handle connection was really sloppy.
Old 03-21-2012, 05:35 PM   #17
padresag
Re: Tranny question
here is one Mark mounted on an a-833 trans
http://www.customclassictrucks.com/t.../photo_01.html
ron
Old 03-21-2012, 06:14 PM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Tranny question
I've never seen one like that before. I've learned something new today which is one of my daily goals. Thanks for sharing the photo.
Old 03-21-2012, 06:57 PM   #19
padresag
Re: Tranny question
guess that I could have given the full link. it even goes on to say that hurst would rebuildd the shifter for these
http://www.customclassictrucks.com/t...n/viewall.html
ron
Old 03-21-2012, 07:28 PM   #20
T Smith
T Smith's Avatar
Re: Tranny question
ron
Interesting transmission there, wouldn't mind having one!
T Smith is offline   Reply With Quote
Old 03-21-2012, 09:06 PM   #21
padresag
Re: Tranny question
they can be found
ron
Old 03-21-2012, 09:37 PM   #22
T Smith
T Smith's Avatar
Re: Tranny question
Looks like the rearward shifter position would interfere with the stock bench seat even if the lever was swapped out.
On second look though the tranny looks awfully short overall so it may still work?
Old 03-22-2012, 12:57 PM   #23
1963c-10
1963c-10's Avatar
Re: Tranny question
ron
Yeah, thats what I meant. Brain fart
Old 03-23-2012, 08:18 PM   #24
Mutt65
Re: Tranny question
Old 03-23-2012, 08:19 PM   #25
Mutt65
Re: Tranny question
Here's a pic. After the fact
loose, play, tranny, transmission
