Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-22-2012, 10:08 PM   #1
68chevyfuelie
68chevyfuelie's Avatar
'86 K35 parting out
'86 K35 for parts. Ex-Ontario Hydro truck. "Should" be 4.56 front and rear, according to paperwork that came with the truck. Transfercase/adapter NOT for sale. Should be cab and chassis frame/rear diff.
Snowplow, Northman 8 foot blade, working when pulled, $300 for everything you pull, $500 I pull
Running Targetmaster 350, $200 you pull, $400 I pull
Working TH400 tranny, $200
Driveshafts $75 each if good
Front Dana 60 $1000 (not inspected yet)
Rear 14 bolt, $500 (not inspected yet)
5 cab roof lights, $50
Grill and trim and bezels, $75
Column, non tilt, with key, $65
Doors, good bottom seam from a quick look, $100/pair
Mirrors and mirror arms, $50
Front bumper, $65
6 rims, $120
Tires, all 6 for $180, front two are like new, back 4 are in good shape
Anything else please ask
Motor can be heard running, truck is still driveable tonight (no brakes, use e-brake pedal )
68chevyfuelie is offline   Reply With Quote
Old 03-23-2012, 08:49 AM   #2
madcow75
madcow75's Avatar
Re: '86 K35 parting out
Look over the doors a little better and let me no how good they are if you wouldn't mind. If they are real good I will take them.
madcow75 is offline   Reply With Quote
Old 03-23-2012, 08:54 AM   #3
mrdana60
why you gotta be so far away ?
mrdana60 is offline   Reply With Quote
Old 03-23-2012, 08:56 AM   #4
owner 84
owner 84's Avatar
Do you have GMC Cab corners on this truck?
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 03-24-2012, 07:19 PM   #5
68chevyfuelie
I don't know, but both are rotten. Sorry.
Old 03-24-2012, 07:20 PM   #6
68chevyfuelie
Pics of RH rims for madcow75:
Old 03-24-2012, 07:21 PM   #7
68chevyfuelie
RH door pics for madcow75:
Old 03-24-2012, 07:22 PM   #8
68chevyfuelie
LH rims:
Old 03-24-2012, 07:23 PM   #9
68chevyfuelie
LH door:
Old 03-24-2012, 09:21 PM   #10
madcow75
madcow75's Avatar
The rear steel wheels for sure. The doors are kind of hard to tell in the pictures. They are GM doors and not aftermarket? There are no seam swelling/rusting. If not I will take them.
Old 03-25-2012, 12:10 AM   #11
68chevyfuelie
I'll get the rears pulled this week and stripped, ready for next weekend if you want them that fast. Otherwise I'll trust you that you'll take them, they can sit here till you want to go for a drive.
Doors I doubt are GM, I can never keep straight the difference in the front door seam between GM and aftermarket. I THINK the OEM doors had a flat seam, and aftermarket had a pinched seam. That's why I tried to show you the front door seam. Either way, I don't see any swell, just some light rust around the drain holes.
Thanks!
Old 03-25-2012, 12:12 AM   #12
68chevyfuelie
You know how many times I've said the same thing on something in Alabama or Texas?
Old 03-25-2012, 09:42 AM   #13
madcow75
madcow75's Avatar
I think I will be going for a drive up there in 2 weeks april 7th or 8th which is a Saturday or a Sunday. I will take the wheels then if thats okay with you. I will pass on the doors thou since they are not OEM doors. Are you going to be cutting that cab up, is it scrap. If so I am still looking for a patch panel cutout around the rear of the cab by the rear window. Basically where the rear cab trim would go.
Old 04-01-2012, 09:15 PM   #14
68chevyfuelie
Top- Let the raping begin!!!
Cab lights, rubbers, screws and harness $50 (harness has been cut where it goes into the dash)
Old 04-07-2012, 09:22 PM   #15
68chevyfuelie
Bump for axles. Both diffs are 4.56 open carrier. Gears appear to be in great shape, no rust, low mileage, oil is nice and clean.
