Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 03-25-2012, 11:24 PM   #1
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Diesel owners, step inside.
Right now I have a 2005 1500HD with the 6.0 that I use to pull a 5th wheel camper during the summer. I'm not really impressed with the power, and certainly not with mileage. I would like to upgrade to a newer 2500HD with either the diesel, or gas. So, the main question would be are the newer (2009-2012) HD's with the gas engine any better on power and mileage? Or would anyone really recommend a diesel? I just don't know, just can't decide if I'd use it enough to justify it.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 03-26-2012, 01:01 PM   #2
Edahall
Re: Diesel owners, step inside.
Diesel engines pull so much better. However, the newer diesel engines don't get the fuel economy that they used to get.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 03-26-2012, 01:41 PM   #3
WestButteTruck
Kung Fu Master
I usually hear the 06-07 LBZ are the best ones to find. I think my stock gasser was only rated at 300 hp.
Old 03-26-2012, 01:59 PM   #4
Lower
Lower's Avatar
I wouldn't pull a 5th wheel with anything less than a diesel. The newer stuff is getting better on mileage with all the tuning software that is available.
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 03-26-2012, 02:56 PM   #5
Maxxd07
Maxxd07's Avatar
I have an 07 nbs diesel and my dad just got an 08 gasser. Both ccsb 3/4 tons and I can spank him in mileage and power. His gasser is pretty impressive for power but he can't hardly afford to drive it since he can't get hardly any better than 10-14 empty or 8 mpg towing. His old 03 gasser 3/4 ton got way better mileage both towing and empty but didn't have the power this newer one has.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 03-26-2012, 03:09 PM   #6
66shortwide
I have a 07 ccsb 4x4 duramax with a tuner, cold air airbox, turbo back exhaust(dpf and cat removed) - gets around 20 mpg on interstate, around 10 mpg pulling my 35' 5th wheel camper. I will not ever pull a camper with a gas motor again.
Trent
12 Cadillac CTS-V
07 Sierra HD 4x4 Duramax
66 C10 Short Wide
63 Chevy II(nova)
66shortwide is offline   Reply With Quote
Old 05-28-2012, 10:51 PM   #7
WestButteTruck
Kung Fu Master
Well, sold the 2005 and was looking for a newer used truck, but decided on a new 2012 Chevy 2500HD Duramax. So far, I think I'm in love
I only have a few hundred miles on it, but the first fill up was just over 18 mpg's.
Old 05-29-2012, 03:39 PM   #8
Edahall
Congratulation!!
06 used to be considered the best year for Duramax equipped trucks but from what I hear, the newest one has surpassed what used to be considered the best.
Old 06-01-2012, 11:22 AM   #9
vin63
It's Better With Nitro
vin63's Avatar
Congrats! I can't recommend the Duramax more for how you intend to use the truck. My '07 CC DRW LBZ pulls and controls my 12K lbs fully laden race trailer like nothing else - 15 mpg.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-09-2012, 04:24 AM   #10
Andy4639
Old member
Andy4639's Avatar
Wink Re: Diesel owners, step inside.
I'm looking to buy a newer diesel sometime soon I hope.
I want to trade my 08 Tahoe in on it and try to keep the payments about the same.
I have a 20' enclosed car trailer I pull with my 08 Tahoe but it's only for short trips. I want something to getter done with.
I want a new 2012 but don't think the wife is going to go for it. 2010 maybe.
What year would be the best?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-09-2012, 07:00 AM   #11
no moa
no moa's Avatar
My LBZ is awesome, when I heard GM was going to DPFs in 08 I found an 07 classic, and I'm glad I did.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 06-17-2012, 06:22 PM   #12
Pro Performance
Pro Performance's Avatar
The duramax's are great! I have an 08 and won't go back to gas. I removed the DPF a while ago and is now straight piped, and love the performance..... it just breathes so much better and gets better mileage.
It is a little harder to remove smog on the 2012, but it can be done. I believe there is one programmer that will delete the DPF codes if you decided to go straight piped.
Enjoy the new truck!
Pro Performance is offline   Reply With Quote
Old 06-18-2012, 10:05 AM   #13
bufmatmuslepants
Junior Member
The LB7s 01-04.5 had injector issues, the LLYs from 04.5-05 had head gasket issues caused by the variable vane turbo, the 06-07.5 LBZs were said to have fixed all of that with lower compression, a better turbo, better injectors, and more power. The 07.5-10 LMMs had the DPF and all that emissions stuff that KILLED fuel mileage and had the same power and frame as the LBZs but in the new body style. The 11-12 LML has a much stronger frame, stronger suspension, gets better fuel mileage and has way more power than anything up until this point. It does have urea injection which is essentially pig piss to reduce NOX emissions, so that is kind of annoying to have to keep filled up. You can remove all of your emissions stuff on your LML but you will void the warranty, and its really hard to justify doing that on a $50-$70,000 truck. In my opinion the 06.5 is the best, because the 07s got the DPF. I have a friend with an 06.5 and a friend with a 07, both OBS, and the 06.5 gets 22mpg, the 07 gets 17 because of the emissions crap.
1979 K10 reg cab short bed 33x12.50s - GONE
1988 4x4 reg cab long bed 337k miles - GONE
1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE
1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE
1994 Z28 M6
1995 Z71 GT4 G80 ext cab short bed 215k GONE
1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE
2003 Avalanche Z71 GT4 G80 165k miles
bufmatmuslepants is offline   Reply With Quote
