Old 05-06-2003, 01:24 AM   #1
hifiguy
68 suburban gas tanks/headers/4x4 parts/power brakes/carbs
I've got a set of Rancho 5000 shocks that I had on a Suburban with a 4" lift. Also have the front 4" lift leaf springs for it. Also have a 20 gallon Suburban/Blazer gas tank for sale (used- it needs a new sender), and 13 gallon auxilliary tank that fits behind the 20 gallon tank of the Suburban. It doesn't have a provision for a sender but makes a great backup tank when you're out in the boonies. Also I have the power brake setup out of my 68 'burb which had front disks/rear drums. I also need to get rid of two carbs. One is a Holley quadrajet, which was working fine when I removed it from my 'Burb, and a Holley 650cfm 4 barrel with vacuum secondaries and the zinc plated finish. And finally I have a set of used Hedman headers for a small block Chevy that will fit a 67-72 4x4. I need to sell this stuff (it's been cluttering up my garage for about a year now) so if you're interested send me an e-mail and make me an offer. I can send pics and more info upon request.
hifiguy is offline   Reply With Quote
Old 05-06-2003, 02:17 AM   #2
68 Suburban
68 Suburban's Avatar
I snet you a PM. I would be interested in the 13 gallon auxilary tank. Where are you located and how much. Thanks.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-06-2003, 04:44 AM   #3
73stepside
73stepside's Avatar
what are you asking for the burb/blazer tank?
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 05-06-2003, 10:37 AM   #4
nightmare
nightmare's Avatar
how much for the holley 650? does it have an electric choke?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-06-2003, 11:20 AM   #5
Custom 68
Custom 68's Avatar
gas tank
I too am interested in the blazer/burb tank. After 73step. let us know where you are located.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-06-2003, 07:46 PM   #6
TROYLV
headers
how much for the headers and where are you located?
troy wilson
TROYLV is offline   Reply With Quote
Old 05-06-2003, 11:12 PM   #7
LeRoy
Registered truck nut
LeRoy's Avatar
I'm interested in the lift and springs depending on your location.
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 05-06-2003, 11:37 PM   #8
68 Suburban
Im still interested in the auxilary tank....thanks
Old 05-07-2003, 02:50 AM   #9
hifiguy
I'm located in the Phoenix, Arizona area. The Holley carb is partially dissassembled and does have an electric choke - $30. The Holley quadrajet is fully assembled and was running fine when I removed it - $75. The auxilliary tank is made of heavy gauge (for a gas tank) steel - $50. The headers need sandblasting and a fresh coat of paint - $20. The 4" front lift springs I think are a heavy duty type, and the shocks were installed in 1999, but have black paint overspray on them and could use a fresh coat of paint, and I don't have u-bolts or rear blocks to go with it - $75. The power brake booster setup with firewall bracket, M/C and prop valve has a new booster as of 2001 from NAPA and worked fine when I removed it - $100. The Blazer/Burb tank needs a new sender and has a dent on the bottom but it doesn't leak and I have the tank straps for it as well - $25. Let me know if you need any additional info or pics. I will ship this stuff wherever, provided you pay shipping costs. Again let me know if you're still interested. Thanks!
Old 05-07-2003, 03:46 AM   #10
LeRoy
LeRoy's Avatar
I PM'd you on the springs and shocks
Old 05-07-2003, 04:34 AM   #11
68 Suburban
I sent you a response to your e mail about the auxilary tank. Lets set something up. Thanks
