Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-27-2012, 10:36 PM   #1
awitate
exterior mirror's mounting screws welded shut
So I wanted to install the original looking mirrors on my 63. Guess what? I found where the screws are suppose to go (under 1/4 inch of bondo) but the kicker is the screws are permanently welded onto the plate. The method they used was basically to hammer the screws deeper into the door, then weld, then bondo. Since it was a big mess(can't see the screw heads) I drilled in to see if i was in the right spot which i was but what do I do now? can I try to drill the screws out? the heads won't come off will they? That first hole is not centered and I probably won't be able to center the remaining 5 so is re-tapping out of the question?
awitate is offline   Reply With Quote
Old 03-27-2012, 11:40 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: exterior mirror's mounting screws welded shut
You might get some help in the paint and body. Moved ya.
Alan's Classic is offline   Reply With Quote
Old 03-27-2012, 11:41 PM   #3
awitate
Thanks!
Old 03-27-2012, 11:44 PM   #4
Alan's Classic
Do you have a pic?
Old 03-29-2012, 08:15 PM   #5
awitate
so I'm guessing that brassy metal is not the original sheet metal
Old 03-29-2012, 09:54 PM   #6
nachodog2
Hell yeah!!!
nachodog2's Avatar
You can always set the mirror a 1/2 inch forward or back of the original locatio, or if you're wanting them in the stock location, you would have to drill throigh and re-tap the holes. Hopefully while drilling and stepping up in bit size the weld will break loose and spin the bolt out. Or hope they welded good and retap. If you go for option one you might want to add a lock washer and nut from the inside. Good luck.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 03-29-2012, 10:01 PM   #7
awitate
Think I'm just going to retapp even if it isn't dead center. I guess bolts and washers too.
Old 04-01-2012, 04:09 PM   #8
MARTYZ
MARTYZ's Avatar
I use a sheet metal hole cutter to cut the weld around the screw, mig a nut on the screw and hopefully it will turn out of the inner plate
MARTYZ is offline   Reply With Quote
Old 04-01-2012, 06:44 PM   #9
awitate
Already tapped it. Those screws were rusted together on that plate. I'm scared to see what horrors lie beneath the passenger side.
bolt, mirror, rusted, screws
