03-31-2012, 03:54 PM | #1 |
3-on-tree to floor
Hey, I recently purchased a '69 c10, and I am wondering if there is a kit I can get to switch the shifter from on the steering column to on the floor.
03-31-2012, 04:33 PM | #2 |
Re: 3-on-tree to floor
Yes. Hurst makes a column to floor conversion kit. Best thing I did to my '69 step side.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
03-31-2012, 04:41 PM | #3 |
Mr gasket makes one also
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-31-2012, 07:30 PM | #4 |
What is the Hurst one called?
03-31-2012, 07:56 PM | #5 |
Mystery Shifter by Hurst. Good luck finding one. Try ebay.
03-31-2012, 11:24 PM | #6 |
How about this one? I'm pretty sure my tranny is a saginaw.
http://www.jegs.com/i/Hurst/530/366-...oductId=748673 Posted via Mobile Device |
03-31-2012, 11:59 PM | #7 |
It would work if you find an installation kit. Hurst doesn't sell them anymore. None on ebay. You could use the kit from a Mr. Gasket shifter and adapt the mastershift to it.
04-01-2012, 07:14 AM | #8 |
Stay away from Mr Gasket, I have one and it's junk, it does actually allow you to select gears in a random manner but it is far from precise. I didn't want to spend the $$ due to future plans of swapping to a 4 speed so I cheaped out.
If I had it to do over again I'd try this... http://www.summitracing.com/parts/HUU-5010016/ Last edited by T Smith; 04-01-2012 at 07:21 AM. |
04-01-2012, 10:55 AM | #9 |
Could I adjust/modify the installation kit from a 4 speed?
http://www.hurst-shifters.com/?wpsc-...7319-chevrolet I couldn't find install kits for this type of application anywhere. Maybe I just suck at the internet. Posted via Mobile Device |
04-02-2012, 11:48 AM | #10 |
You could use one from a 4 speed. Depends on your skills and on the size of your wallet. Won't be a bolt on. I used one on a 56 chevy 3 gear once.
FWIW I've used the Mr. Gasket shifters on 4 different trucks and have had no problems. You gotta set em up right is all. And they're cheap on ebay. Compare 400 for a hurst and kit to 40 for a Mr. Gasket. |
04-02-2012, 07:10 PM | #11 |
I found an installation kit for a Hurst mastershift when I was looking for parts for my hotrod today. If you're interested pm me for info.
Tags |
3 on the tree, three on the tree, transmission |
