Old 04-03-2012, 01:08 PM   #1
neo9
'64 Drop member install Trans Hump
Does anyone know if replacing the low trans hump with the tall trans hump necessary with a PB dropmember. Almost every post I see has the hump replaced with the tall hump?
neo9 is offline   Reply With Quote
Old 04-05-2012, 02:19 AM   #2
RAYDAY
RAYDAY's Avatar
Re: '64 Drop member install Trans Hump
the hump is not from using a dropmember it more from running an auto tranny not alot of room in there for auto especially an OD.
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 04-05-2012, 07:43 AM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think the DM moves the engine up a couple of inches, which is why it works better with a high hump
Old 04-05-2012, 10:02 AM   #4
biohazardbill
Tis True...
If running a big block even the high hump isnt enough.
biohazardbill is offline   Reply With Quote
Old 04-12-2012, 10:36 PM   #5
begining87
begining87's Avatar
So where is the best place to find a tall hump. I assume these are taken from 4x4'? I have looked and I can not find any one making these as a replacement. Thanks
begining87 is offline   Reply With Quote
Old 04-12-2012, 10:49 PM   #6
64shortc10
64shortc10's Avatar
They came on 4x4's but they came on any 2wd with a 4 speed tranny. I have 3 2wd's in my driveway they all have the bolt in high hump. So look in junk yards for the 4 speed version. The hump bolts in, but you also need to drill out the spot welds for the front portion the hump bolts to! Good luck.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 09-26-2012, 09:32 PM   #7
64Downunder
64Downunder's Avatar
I am also looking for the high hump if anyone knows where to find one let me know plz.
My 64 has a 4 speed but wouldn't know if it was in there before or not, the truck is in shipping and i haven't seen it in person yet so cant check.
Would the vin tell you what gearbox i had?
64Downunder is offline   Reply With Quote
Old 09-26-2012, 11:03 PM   #8
begining87
begining87's Avatar
Thanks 64 shortc10 for the help. I am searching..
Old 09-27-2012, 06:35 AM   #9
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
arizona parts steve almeter helped me and got me both pieces 585-314-7907 let him know dave from ny with the suburban sent you he may be able to get you what you need he kind of specializes in these trucks.
gostranger is offline   Reply With Quote
porterbuilt, trans hump, transmission cover
