Old 04-04-2012, 11:18 PM   #1
72 Madness
72 door panels will 70-71 fit mine
Ok guys, I have a question I have been told from so many people that a 70-71 door panel will fit on my 72 blazer. I like the metal flat panels more than the cheap plastic ones that come with mine. Will they fit or not. I have been told two different things from so many different people. I need some help before I buy some.
72 Madness is offline   Reply With Quote
Old 04-04-2012, 11:20 PM   #2
bigblock68
bigblock68's Avatar
Re: 72 door panels will 70-71 fit mine
the regulators for the windows and door latches are longer on a 72,also the way the earlier panels screw on the bottom will have to be dealt with.
bigblock68 is offline   Reply With Quote
Old 04-09-2012, 09:33 PM   #3
BOHICA
BOHICA's Avatar
How do the panels attach differently?
The PO swapped a '72 driver's door onto my '70 Blazer, and while I may be missing something, I don't see any difference with how the panels mount.
1954 Ford F-100
1956 Chevy big window
1970 4x4 Blazer CST
1987 Land Cruiser
1990 Chevy K3500 454
BOHICA is offline   Reply With Quote
Old 04-09-2012, 09:48 PM   #4
bigblock68
bigblock68's Avatar
the 72 door panels are attatched with plastic clips and the earlier ones are screwed on.
Old 04-09-2012, 11:36 PM   #5
72 Madness
Well, I bought some today at pull a part. They do line up but you are correct the window and door spindles are a little longer. I'm just going to drill holes to connect them and try to figure out what to use to cover up that spindle.
Old 04-10-2012, 12:14 AM   #6
oldschool18
oldschool18's Avatar
could you get a set of window regulator from a 70-71 swap in? are the truck and blazer regulators the same
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 04-10-2012, 11:08 AM   #7
29od1
The truck and Blazer regulators are the same. And the regulators from 67-71 are all the same. Only the 72 regulators are longer to make up for the door panel change.
29od1 is offline   Reply With Quote
Old 04-10-2012, 11:49 AM   #8
SamMargritz00
SamMargritz00's Avatar
you'd have to use the 71 style doors to use those panels w/o any modding. Mine original doors were in bad shape and i like the 71 style panels so i bought truck doors and cut the window frame off since it was cheaper that way then buying blazer doors for my 72. but you might be able to get away with recovering them like mine depending on how much longer the cranks are. just an idea i guess.
SamMargritz00 is offline   Reply With Quote
Old 04-11-2012, 01:31 PM   #9
72 Madness
Thanks alot. Those look really good.
Old 07-11-2018, 09:04 AM   #10
cgalek
Has anyone tried to just grind down the spindles a bit?
cgalek is offline   Reply With Quote
Old 07-11-2018, 11:59 AM   #11
SeventyOne
Is the actual splined part long enough to grind down and still be functional? I bet not.
SeventyOne is offline   Reply With Quote
Old 07-11-2018, 12:53 PM   #12
cgalek
Yeah, looked today and you nailed it. Splines dont go all the way down.
Old 07-11-2018, 06:06 PM   #13
1rippen6
I know I have 1 71 window regulator not sure if I have 2 if interested.
1rippen6 is offline   Reply With Quote
