wh1skea's Projects (68 C20 & 70 C10)
Bought a 68 C20 last May.
![]() ![]() ![]() ![]() Since then I've added some artwork, removed the sides off the stakebed, and swapped the 307 for a 327 with double hump heads. ![]() ![]() ![]() |
Re: wh1skea's Projects (68 C20 & 70 C10)
This week, I bought a 1970 C10. It still has the inline 6 and 3 speed transmission.
Not been having much luck with the 2 Holley carbs I've got, so the C20 is going to go back to being a 2bbl truck. So seeing as how I painted the 327 before I swapped it for the 307, I cleaned the 2bbl manifold from the 307 and painted it too.
Got the intakes swapped. Also got the glasspacks installed. Carb is still flooding some, so pressure regulator seems to be next on the list. That and an upper alternator bracket. The stock one doesn't seem to work with the header brackets I've got.
