Old 04-11-2012, 07:26 PM   #1
**grumpy**
**grumpy**'s Avatar
Will these stepped A-arms work?
What do you think?
They are welded on every single flat place, top and bottom.
The guy has been welding for years and has built alot of stuff.
And theres a heavy guesset thats not so noticable on bottom.
I wanna run these on my 64 to keep drum brakes..
Road Hounds
**grumpy** is offline   Reply With Quote
Old 04-11-2012, 07:57 PM   #2
SCOTI
SCOTI's Avatar
Re: Will these stepped A-arms work?
As long as you trust the welds, they look to be 'built' correctly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-12-2012, 09:41 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I don't see a problem with the arms. Drum brakes, not so much.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-12-2012, 11:43 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
Kevin Ehresman in Dayton has done modified control arms like that for years. Works just fine. That used to be a common fix to lower a car that you can't find dropped spindles for.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-12-2012, 11:49 AM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
I just built a set but I changed the angle of the ball joint before i welded it, just to correct it more....also pie cut the uppers to correct slightly.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 04-12-2012, 12:13 PM   #6
**grumpy**
**grumpy**'s Avatar
These were a spare set, so Im going to run them, and if theres a problem, I can always swap back.
Drum brakes are fine. Its got all new wheel cylinders, hardware kits, and dual master cylinder. It'll stop fine. I may run synthetic brake fluid just to aid in less brake fade.
They got new balljoints and theyre painted up, so today the front comes apart.
Is there any steering issues I'll run into? Shouldnt be any different than using 2.5" drop spindles right?
Road Hounds
Old 04-12-2012, 03:45 PM   #7
juanz1947
rusty 66
juanz1947's Avatar
What did it cost to have them done
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 04-12-2012, 10:50 PM   #8
**grumpy**
**grumpy**'s Avatar
Nada..zip..zero..
They were a set off my buddys 63 burb. He put all rebuilt 72 stuff under his and I took all his stock 63 stuff.
Me and my kid helped him swap and bag his burb, so he did the Aarms for me.
I measured tonite, they equate to a 2-1/8" drop, so we'll see how it goes.
Road Hounds
Old 04-13-2012, 12:37 AM   #9
RAYDAY
RAYDAY's Avatar
them should work good. and Matt know what hes doing ide trust them.
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 04-13-2012, 04:40 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
Looks good to me since you're not running drop spindles.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
