Old 05-09-2003, 07:58 PM   #1
trukkers69
seat question?
I'm thinking about putting 88 &up seats in my 69, but i am concerned about leg room .If i take the tank out from behind the seat how much more room will that free up?
EXPERIMENTAL STAGES OF SANITY
_____________________________
Run whatcha brung, and hope you brung enuff
trukkers69 is offline   Reply With Quote
Old 05-09-2003, 08:24 PM   #2
cdowns
cdowns's Avatar
not a whole hell of alot 1-2 inches maybe
Old 05-09-2003, 10:37 PM   #3
Class of 69
Class of 69's Avatar
The seat is still restricted from rear movement by the inner body panel under the window. I can barely get my fingers between the panel, and stock seat, in full rear adjustment.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-10-2003, 07:44 PM   #4
Huck
Huck's Avatar
The gas tank doesn't restrict rear movement of most seats. The backrest hitting the inner wall of the cab just below the window is the problem. If you jack up your seat a bit so that the backrest comes above that inner wall, you can gain about an inch of leg room or 2 inches of belly room. I jacked up my buckets by putting them onto a 2x4 and added a tilt column. You can also move the steering wheel forward via the column if you like. It's a little more work but it can be done.
Huck is offline   Reply With Quote
Old 05-10-2003, 09:16 PM   #5
trukkers69
Well........ i thought there may have been a little better solution than losing "a few extra pounds " but i guess theres not.
