Old 05-01-2012, 02:29 PM   #1
dliving69
dliving69's Avatar
Supercharge
Looking to put a super charger in my c10. Its a stock engine, is there anything needed to be done to be able to do this or could I just buy this set up im looking at and put it on? Carb engine.
dliving69 is offline   Reply With Quote
Old 05-01-2012, 03:07 PM   #2
bonnieclyde100
Re: Supercharge
you need to make sure your engine can handle the extra power and you need to know what compression ratio your stock engine is at to make sure its not to high for the supercharger.most engines nee to be around 8 to 1 ratio to handle a supercharger. also you need to know what your rev limit is on your engine so you dont over rev it and break something. if your engine is a 2 bolt main you might not want to put a charger on it a 4 bolt main would be better to handle the extra power.
bonnieclyde100 is offline   Reply With Quote
