Old 05-08-2012, 07:16 PM   #1
BMERDOC
BMERDOC's Avatar
New Project New Problems!
I got my latest project running (carb rebuild, new plugs, gas can in the floor board) but had troubles getting it to run smooth enough to warrant breaking out the vac gauge and tuning the carb. I was working through the problems I was having and figured a compression test was in order. Everyone was between 145 and 150 psi except for cyl 3 which turned out a paltry 25 psi. Oil in cylinder didn't raise compression so I pulled the valve cover and found this. Turns out the intake valve is stuck! Dang! Oh well, time to straighten this out!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 05-08-2012, 07:31 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: New Project New Problems!
Hope that's all it takes to get it running well! (all used lightly since I know it's a fair amount of work....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-08-2012, 07:34 PM   #3
Gene
Gene's Avatar
Install another pushrod and run the valves again. I had a bent one and because the rocker came off
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 05-08-2012, 07:43 PM   #4
midniteblues
midniteblues's Avatar
looks like your still missing a peice
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 05-08-2012, 07:45 PM   #5
BMERDOC
BMERDOC's Avatar
I rapped on the top of the valve enough to break spring pressure but it didn't budge. I'm gonna remove the spring (using the proper precautions) to see if I can get it to free up. Other than that the head needs to come off.
Nick Carter
Old 05-08-2012, 07:47 PM   #6
BMERDOC
BMERDOC's Avatar
Yes Sir! I noticed that myself! I have the patience of a Saint and will try to fish it out magnet style. We'll see what happens.
Nick Carter
Old 05-09-2012, 10:54 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
any progress?
Old 05-09-2012, 11:49 PM   #8
BMERDOC
BMERDOC's Avatar
I will happily report that there was some good progress today! I brought my 22oz. ball peen and my brass hammer home from work. I figured if it was terminal then I couldn't do any worse by messing around with it. I made sure I had clearance between the valve and piston, laid my brass hammer on top of the retainer and mildly popped it squarely with the peen. No big over-the-head swings just deliberate. With two good wacks I noticed the valve was moving but not returning. I gave up and went in the house for a minute but then came back out and thats when I noticed it was back up. I went back to it and was able to get the valve to open and close. The NAPA on Staples Mill has the push rod in stock($2.00). I'll put it in and rotate the motor over to check for flat cams and binding. I'm going to use the boroscope to attempt to find the last piece of the push rod and retrieve it with my trusty flexible magnet.
I know, I know. I can jerk the heads off and machine this and rebuild that. Gene's comment about throwing another pushrod in it and running it is closer to my attitude than he ever thought. To me, this motor is a huntin' dog and not a house dog. So if I throw it out there and it don't hunt...it don't have a home. If I can get it to the point where I can get a timing light and a vacuum gauge on it I'm happy. If it doesn't last, I'll address it then. I may never see another problem from it.
I will say it was "sticky" and not "stuck". Stuck like rusted in. It was sticky like oil or goo so that may indicate a worn guide. I'm gonna chuck in that $2.00 push rod and let you know what I find.
Nick Carter
Old 05-10-2012, 12:00 AM   #9
BMERDOC
BMERDOC's Avatar
If your browsing and wondering what truck I'm refering to...
http://67-72chevytrucks.com/vboard/s...d.php?t=520782
Nick Carter
Old 05-10-2012, 12:05 AM   #10
VA72C10
VA72C10
VA72C10's Avatar
cool....sounds like a good plan.
Old 05-10-2012, 06:56 AM   #11
68C15
blood type; Retumbo
68C15's Avatar
normally I cringe at the thought of any additive but I will stand behind my suggestion of Marvel Mystery Oil. add 1/2 quart and run it at idle for a half hour then change oil.
you have sludge/varnish on a few valve stems from it sitting. the ones that were in the open position got a chance to get a build up.
good luck, I like your thinking
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-10-2012, 08:58 AM   #12
BMERDOC
BMERDOC's Avatar
Once I get it chugging along nicely and see that valve pumping up and down I do intend to follow a routine not unlike what you have suggested. I did just about the same thing with the I6 in my '67. Once that one was running I got it nice and warm, drained the oil overnight then when refilling I substituted 2qts ATF for oil for its high detergent properties. I changed the filter a couple of times and then drained the oil and am now on a regular schedule. Neither motor was dirty on the inside at all. I will probably use MMO this time to experiment. Lets see what happens.
Nick Carter
Old 05-10-2012, 12:26 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
thinking about it I'd wager MMO is at least part ATF because of its' color
Old 05-10-2012, 08:08 PM   #14
BMERDOC
BMERDOC's Avatar
Back at it again today. Went out and "exercised" the #3 intake valve again. I used the boroscope to look down in the valley but I couldn't find my missing piece of push rod but I did see that the lifter was ok. I installed the push rod and adjusted it, spun the motor over with the valve cover off, everything looked fine. I did a compression test and it showed 150 psi! Time to fire it up! Cranking sounded way better than it had and then it fired right up. Woo hoo! I let it warm up a bit so that it would hold its own idle and went to adjusting the idle mixture. I couldn't get it any higher than 14 H.g. but as it idled the speed increased (I had to incrementally decrease idle) and vacuum reached 17 or 18 H.g.. It still shakes a bit but throttle response is good and the vac needle is steady. I checked the timing and its at 15*, the spec is 8* at 600rpm but I didn't have my tach with me so I didn't touch it for now. The vac advance is also on a ported supply so I'll have to do the research and find out what the vac advance was supposed to be connected to. It was running 30* with the advance connected. My gas can ran empty before I got tired of tinkering. Looks like this problem may be licked and I can continue getting it road worthy. Now for some pics.
Nick Carter
Old 05-10-2012, 08:26 PM   #15
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Curious to hear where the piece went. I bet that boroscope is invaluable in certain situations.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 05-10-2012, 09:31 PM   #16
midniteblues
Now you can tell everybody you fixed the engine with a couple of hammers!lol
Old 05-10-2012, 09:49 PM   #17
BMERDOC
BMERDOC's Avatar
I have to work on science projects all day. It gives me great satisfaction to do what I want to get them running by my own laws. I would go at it with a 5lb. sledge if I had to! LOL! BTW, I'm no stranger to making it work. I had a problem with my I6 when I got it fired up...
http://67-72chevytrucks.com/vboard/s...d.php?t=478290
Nick Carter
Old 05-10-2012, 10:03 PM   #18
BMERDOC
BMERDOC's Avatar
I'm not sure where that piece went. I'll have to pull the intake to find it. So much for the boroscope helping here but yes it does help. Too many of the holes in the head had flashing around them and wouldn't allow me to get the camera into the valley. The head is only 1/4" diameter but still too big. I wanted to post pics but cant find the cd to load the SW onto my laptop. The 'scope has the ability to both take pics and take video.
Nick Carter
Old 05-10-2012, 10:09 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
cool deal! Curious about the piece too....hoping it doesn't cause issues later but maybe just sitting in the lifter valley???
Old 05-10-2012, 10:18 PM   #20
BMERDOC
BMERDOC's Avatar
I dont think it'll hurt much then again I'm not completely sure how big it is. The rod measures at 7.79". I can measure the remnants to see whats missing. I can only imaging that it would be a problem if it found its way through one of the big drain holes at the front of the motor, by the timing chain or in the holes above the camshaft. I'm trying to not think about it but it does bring up one of my favorite words: inevitabilty. Eventually, I'll have to remove the intake to retieve it.
Nick Carter
Old 05-11-2012, 06:14 AM   #21
68C15
blood type; Retumbo
68C15's Avatar
it's probably in the pan by now. there, I said it. sue me. LOL
Old 05-11-2012, 06:55 AM   #22
Gene
Gene's Avatar
Take a large magnet and stick it on bottom of oil pan. If its there the magnet will keep it secure.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 05-11-2012, 07:11 AM   #23
midniteblues
There has been many items found in lifter valleys and oil pans.
maybe for assureance pull the dizzy an stick that badass scope in there.If you still dont see it then its stuck in the sludge in the pan an you could forget about it or use the magnet on it
Old 05-11-2012, 09:24 AM   #24
BMERDOC
BMERDOC's Avatar
It suddenly occurred to me that I'm going under the assumption that it is only ONE piece! I'm still convinced it is but you never know. I save all magnets when I swap trans pans so maybe I'll throw one on the pan by the drain hole. maybe I'll throw a couple on the oil filter too. I'm not sure how much sludge is in there because the top of the heads are suprisingly clean.
Nick Carter
