Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-09-2012, 12:18 PM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Alternator problem 01 blazer
Today the alternator/battery light came on in my 01 blazer and the voltmeter was sat at 0, now the voltmeter has occasionally sat at 0 before without the warning light being on which I put down to maybe a sticky/iffy gauge. Is it likely that my alternator has breathed its last or is there something else taht could be causing this like a charging relay somewhere? The reason I ask this is that just before I got home after the light came on the speedo suddenly went nuts bouncing up and down and several other warning lights flashed on and then it all went back to normal after a second or two.
Any help appreciated, it appears to be a one wire alternator so how do I test this, I have a meter.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
