Old 05-12-2012, 05:37 PM   #1
Lee H
Lee H's Avatar
1972 Medium Olive Poly 504, PPG #2097?
I'm having a hard time finding some place to get UB Basecoat made to PPG #2097, 1972 Medium Olive Ploy 504. I'm sure someone has found it. Any help will be much appreciated. Thanks, Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-12-2012, 06:07 PM   #2
71 super
71 super's Avatar
Re: 1972 Medium Olive Poly 504, PPG #2097?
Dupont is what is used on my 72 medium olive. I used PPG on black and white because of high solids content in clear, the dupont waxes it tail, never again with the ppg.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-12-2012, 10:34 PM   #3
dfwright
dfwright's Avatar
Marking for reference
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-02-2012, 10:03 PM   #4
dfwright
dfwright's Avatar
I see you found your medium olive paint! What did you end up with, and where did it come from, if you don't mind my asking. Do you have a build thread or pictures posted?
Old 10-02-2012, 10:19 PM   #5
Lee H
Lee H's Avatar
Ok, this is what i ave found out, the old paint codes (pre 80) made with todays base coats do not look like the old colors, they are way off. Single stage urathanes are pretty close. For two stage you need to have the base custom mixed to the old chips or a panel. I had mine custom mixed by Twin Cities Paint in San Diego. Not perfect but close. No build thread but I do have a short album in my profile that I add to every once in a while.
Old 10-03-2012, 09:02 AM   #6
dfwright
dfwright's Avatar
Thanks for the information, this is good to know. I guess I had better save the backside of my glovebox door to use to color match. I looked through your album. Are you doing the painting yourself? That truck is looking fantastic!
Old 07-26-2018, 01:49 PM   #7
Auroch
Auroch's Avatar
Amazing trucks here guys, thanks so much for all the input.
I'm thinking about going Medium Olive 504 and white (I think it's 521?) roof.
Auroch is offline   Reply With Quote
Old 07-26-2018, 02:01 PM   #8
dfwright
dfwright's Avatar
Excellent Choice! There are a number of threads you can search on the board about some of the difficulties with matching the 504 color using today's paints. I ended up using PPG's OMNI line of paint, and had the paint shop mix me up a small can to test with. I was shocked at how well it matched, when I compared a test panel with my original glove box door.
Old 07-26-2018, 02:07 PM   #9
Auroch
Auroch's Avatar
Oh wow, that's flawless man. So I was getting some quotes here and there, I found a shop that uses Nason paint, it was considerably cheaper and honestly the cars they had on display looked great + 5 year warranty included on the work. Any thoughts on that brand of paint?
Old 07-26-2018, 04:32 PM   #10
dfwright
dfwright's Avatar
Unfortunately, I've only ever painted one vehicle. This one
The board here does have a paint and body section, you should pop over there and ask. There's some very knowledgeable folks over there.
Paint and Bodywork Forum
Old 07-27-2018, 01:03 PM   #11
jocko
jocko's Avatar
Is that a GMT 400 hood? Are you planning to paint that truck this color? (or just the test strip as mentioned) I bet it would look fantastic.
Old 07-27-2018, 04:21 PM   #12
dfwright
dfwright's Avatar
That's a spare hood off my '95 suburban. My son ran it into a tree, so we put a junkyard hood on the suburban, and I kept the old one for practice body working and painting. The thought had occurred to me, when I saw how nice the hood turned out. I was thinking maybe a two tone with this green on top, and silver below the trim line would look good.
Old 07-27-2018, 04:40 PM   #13
jocko
jocko's Avatar
Agree, that would look nice. I like the GMT400s, but not a lot of great color choices compared to the 67-72 era. I have a "practice" fender, same purpose, ha. I probably need a "practice" truck,
Old 07-27-2018, 06:34 PM   #14
57taskforce
All about them K’s
57taskforce's Avatar
If your anything like me a practice truck quickly turns into a project which then turns into a yard full of projects and not enough time or money to do them the way you’d like
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 07-28-2018, 11:11 AM   #15
mrein3
mrein3's Avatar
FWIW, I sprayed my truck with PPG's Omni. I'm REALLY happy with how it turned out.
I also really like their Omni MP170 epoxy primer. I just about fainted when my local jobber rang up my last gallon. It cleared the two hundred dollar hurdle by two dollars! It was $202 with two quarts of the activator.
If you spray MP170 on properly treated metal, you're done. That stuff ain't coming off unless you want it to.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-28-2018, 01:17 PM   #16
dfwright
dfwright's Avatar
I used the MP170 myself, and agree that it's very good. I scratched the paint a time or two when I was putting the truck back together, but never managed to scratch through the epoxy.
