Old 05-25-2001, 08:05 PM   #1
68 Suburban
68 Suburban's Avatar
Question Looking for a gas tank for a 66 panel?
Are these hard to come by?
68 Suburban (Updated 5/15/01) http://216.247.187.89/suburban/68sub1.htm
Phoenix, AZ.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-25-2001, 08:31 PM   #2
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Post
Yep, hard to find, many use plastic tank from GMCPaul's, I took tank from GM sunbird, had to beat on it a bit to fit, used pu from chevyvan with electric pump, used return line for main fuel, with shorter pickup, when I run out, I switch lines with valve, hit button on dash to kick in pumo in tank to prime, have another 1-1/2" of gas! What's your truck like?
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB 350 from '68, 3spd, restoring
68 C10 LWB 250 from '66 4spd, dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
Nevada City, CA
Everett, Washington
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 05-25-2001, 09:36 PM   #3
u2slow
Web Wheeler
u2slow's Avatar
Lightbulb
Slick instrument cluster! What are the guages from?
I hate chasing down stock fuel tanks - big PITA. I put a brand new (jobber) 73-91 Blazer tank in my shortbox 4x4. 31-gallons. I can actually pass a gas station now!
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 05-26-2001, 12:47 AM   #4
68 Suburban
Post
I am looking at a truck to buy that needs a tank.
Phoenix, AZ.
Old 05-27-2001, 03:04 PM   #5
u2slow
Web Wheeler
u2slow's Avatar
Post
You can have them repaired/relined too. I had this done to the in-cab tank on my 66 C10. They soldered a patch on the hole, and sealed the inside with a red coating. I was warned not to run fuel with any methanol additives since it would dissolve the liner.
Cost me $150 CDN.
Knowing what I know now, I'd have put some other tank in instead.
Old 06-06-2001, 12:23 PM   #6
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Post
Guage panel from photo above is from 2 blazers, blazer has 2 big holes, not three; this way I get tach, speedo, and clock. It is eaxy to cut the plastic guage box and cut the metal bezels and join 2 together. I soldered patch wires between sections of the printed circut boards together, just scraped off the plastic coating to get to the copper.
Nevada City, CA
Everett, Washington
Old 07-04-2001, 01:37 PM   #7
wacko
Post
I have one of these. If you REALLY need it, I guess I could part with it. It is in pretty good condition. Let me know.
wacko is offline   Reply With Quote
