Old 05-17-2012, 01:15 AM   #1
JKady
Biggest rear tire on a C10
Wondering what the biggest/widest rear I can run on my '70 is before the frame starts to interfere? Basically want a pro-street look without having to rebuild the whole rear of the truck since it's my daily driver and I like how it drives. Planning on a drop to be decided after I get the tires and wheel package under the truck. I'm running 31x10.5 now and they've got a lot of room, but big big street tires aren't something I can just run down and grab from the local used tire guy so I would like to know what fits before I go dropping coin on new shoes.
JKady is offline   Reply With Quote
Old 05-17-2012, 01:18 AM   #2
70cst
70cst's Avatar
Re: Biggest rear tire on a C10
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is online now   Reply With Quote
Old 05-17-2012, 07:14 AM   #3
68Stepbed
68Stepbed's Avatar
The frame interference isn't the problem, it's the wheel tubs. Do you have a stepside or fleetside? Are you lowered any, or plan to lower it any? What size (dia) wheel do you want to run? These are important questions that need to be addressed before any real answers can be obtained.
Check out Hart Rob's 6T8ZZZ farm truck build. It's slightly tubbed with widened stock wheeltubs, and it's been through several sets of wheels before it's current 18/20 combo. That might help with an idea of what may fit.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 05-17-2012, 09:28 AM   #4
hgs_notes
GEARHEAD
hgs_notes's Avatar
I used to have 295-50-15's on the back of mine. It was lowered with springs 3.5" and no other mods. The tire on one side would rub the wheel tub in turns with body roll. It was probably off center by about 1/4".
For a really fat tire you have to cut the bed and widen the wheel tubs.
hgs_notes is offline   Reply With Quote
Old 05-17-2012, 09:40 AM   #5
JKady
Thought I had all that in there but I guess I left everything out re-wording my original post. '70 fleetside. Want the biggest tire I can fit after tubbing. Like I said, drop will come after my wheel/tire package is set
Old 05-17-2012, 10:26 AM   #6
RexDodge
I think what Matt was saying is good advise. Before picking your tire wheel combo you need to decide on the amount of drop you want. The inner wheel wells slant in at about a 45 degree angle a bit before they go up on these trucks. You'll need to consider that when you fab your new wheel wells. Without changing that you're going to look like the guy in hi school that slaps air shocks on and some big tires (no disrespect intended to anyone). To pick a wheel or at least start the planning process I would suggest you take some measurements. Figure out how much back spacing you can get by re-working your wheel wells. Measure from the face of your drum/axle to the back of the wheel well (or the point you intend to widen it to) and then do the same for the front spacing. Take a couple of inches off that measurement and that would be the maximum width you can run with not hassles. Remember..you need to "modify" that outer lip or you'll rub. Many wheel manufacturers have options for back spacing. If you want that "pro street" look you can make your tubs wider (takem to the frame) and order a set of wheel with the maximum back spacing allowable for your application and that will move the wheel to the inside. Get yourself some drag radials and your stylin...start measuring and have fun. Do a search on this site and I'll bet someone has done a write up on a similar project.
RexDodge is offline   Reply With Quote
Old 05-17-2012, 04:59 PM   #7
68Stepbed
68Stepbed's Avatar
Yep, you're getting your cart in front of your horse. You need to decide on the drop you want first, then decide on wheel/tire setup. Actually, you need to decide both at the same time.
Matt
Old 05-17-2012, 05:57 PM   #8
Ackattack
Ackattack's Avatar
I'm on airbags, so probably 4-7" drop depending on where the bags are set. I tubbed the rear wheel wells and my wheels set the tires ~1/16" from the inner wheel wells at full dump. They are 315/35/20. I have about 2" or more on the inside of the wheelwell.
Ackattack is offline   Reply With Quote
Old 05-17-2012, 09:29 PM   #9
JKady
How about we pretend for a moment there are no wheel tubs if that'll help, I have a sawzall, I can put the tubs where they need to be after the fact. Sheet metal is very mobile, ask anyone that's watched me put 33-35" tall tires on a stock height rig. Lets just throw 4" out there as the max I'll drop the thing.
Old 05-17-2012, 09:41 PM   #10
1968ratrod
1968ratrod's Avatar
14 or 15 inch wheel and about 18.50 tire with the right offsets.........
1965 Chevy Suburban
2003 Chevrolet S10
2011 Harley Streetglide
1968ratrod is offline   Reply With Quote
Old 05-18-2012, 12:58 AM   #11
QKENUF4U
QKENUF4U's Avatar
with tubs you can fit a 31x18.5 on 14" rims w/ 10bs.. wont touch a thing... good luck getting them balanced though (wont fit on tire machines) you could bubble balance them though...
QKENUF4U is offline   Reply With Quote
Old 05-18-2012, 01:26 AM   #12
JKady
NICE! Any more pics or a build thread?
Old 05-18-2012, 02:07 AM   #13
mike hancho
I'm running 295/65/15 stock Stepside. 15x10 with 4 inch backspace. Fits perfect
mike hancho is offline   Reply With Quote
Old 05-18-2012, 06:29 AM   #14
darkhorse970
darkhorse970's Avatar
What brand tire is that? Can you post pics?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 05-18-2012, 08:01 AM   #15
LEX
LEX's Avatar
This member ran a 28x13.5x15
LEX is offline   Reply With Quote
Old 05-18-2012, 09:55 AM   #16
Hart_Rod
Hart_Rod's Avatar
I'm running a 31 x 16 tire on a 20 x 12 wheel. The only thing that is done to mine is widened wheel tubs.
Hart_Rod is offline   Reply With Quote
Old 05-20-2012, 12:14 AM   #17
mike hancho
Mickey Thompson et street
Old 09-02-2013, 08:20 PM   #18
70blackfish
Anymore pictures?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 09-03-2013, 02:05 PM   #19
codeJbird
codeJbird's Avatar
I have 20x14's w/ a 29x18 wide tire. tubbed of course, no frame work
Bird
codeJbird is offline   Reply With Quote
Old 11-30-2014, 06:55 PM   #20
jst4fun
i see this is an older thread but was wondering what offset the guy with the 20x12 has as I am looking at doing them for my 72 c10 swb
jst4fun is offline   Reply With Quote
Old 11-30-2014, 11:22 PM   #21
70blackfish
I installed wider tubs, and 29/15/15 M/T tires
Old 12-01-2014, 12:05 AM   #22
jst4fun
I am thinking I am going to be tubbing mine as well. Really want to go with 20x12 rims on the back as i will be dropping a 572 and a t56 magnum 6 speed in with a dana 60. Just was curious what backspacing hart rod had on his.
Old 11-29-2016, 09:06 PM   #23
Theboatandcarman
I am shooting for 315 wide on the rear of my c20 fleetside. Looks like I'll need around 5" back spacing?
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 11-30-2016, 07:52 PM   #24
71threequarterton
71threequarterton's Avatar
Sorry I can't directly answer your question but I plan on running Wheel Vintiques 16x10 w/ 5" backspace and most likely a 305 70 r16 tire on my 71 C20 fleetside.
I will pull the current wheel off and try the 16x10 wheel on before I get tires mounted, just to make sure the backspacing is right. This is on the REAR ONLY.
I am curious to know how a 315 fits on a C20 fleetside. What will your exact tire size be?
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
71threequarterton is offline   Reply With Quote
Old 12-01-2016, 06:23 PM   #25
Theboatandcarman
I'm shooting for 315/35r20! I'm only dropped 3/5" so it should be clear, I'm gonna have to Re drill a tire/rim fitment gauge for 8 lug
1968 Chevrolet C20
1970 Mercedes 280S
