05-24-2012, 12:46 PM | #1 |
New project underway! My first!
I couldn't resist the urge any longer, so I broke down and bought myself a 71 k5 Blazer. A lot of work to do, but the basics are there...
Questions: 1. I'm thinking line-x or rhino liner for the whole interior and just throwing down rubber mats. Will it get too hot? It does have a 2" body lift so there'll be a little distance between the exhaust and floor. 2. Anyone have billet dash cluster? I'd like to get one, but have concerns with sun glare? Anyone experience this? |
05-24-2012, 09:30 PM | #2 |
Just a nother gear head
Re: New project underway! My first!
looks like a nice base to start. we love pics so post up more.
1. i dont think the line x will cuz it to be to hot. lots of 4x4 guys use it in and under the rig. 2. they make billet dash bezels so dont think the glare will be any worse than it is off the glass or lense of the gages.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
05-25-2012, 02:37 AM | #3 |
Collector of Projects
The Line-X is not a heat barrier.... use Lizzard Skin on the underside, OR ask the line-x guys if you can put the Lizzard Skin down under the Line-X... there may be compatability issue with the two products...
05-25-2012, 03:26 PM | #4 |
I don't know why but something tells me the line-x would make it like an oven inside...
05-25-2012, 03:47 PM | #5 |
VA72C10
Welcome to the board. I know a lot of guys run bedliner on their interiors...never really heard a complaint about the heat....my 71 had it but I put pad and carpet over it.
Looking for a 67-72 swb or blazer project in or around VA. |
05-26-2012, 04:13 PM | #6 |
It does ask me how I know
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
05-26-2012, 04:28 PM | #7 |
05-27-2012, 10:10 AM | #8 |
As said above by mcmlix bed liner materials are not a heat barrier but Lizzard Skin is made up different, it does claim to be a heat barrier. I can't testify to that claim but others can, I have Al's Liner on my complete floor, looks good but it's hot. Most likely due to the motor/exhaust heat, truck has no lift which may give you a little better air flow. If I were to do it again it would be Lizzard Skin underneath cab then carpet and pad. And thats just one option.
05-29-2012, 05:15 PM | #9 |
Broke and still trying
I have a liner on my roof in/out, and on the floor. I think it's Rhino but not certain. It doesn't block out the heat. I have dual 2.5" flows and I can feel the warmth.
05-29-2012, 08:48 PM | #10 |
you will feel the heat liner or no liner. only way to block it is with isulation like jute or lizard skin. i had bare painted floors in my 84 c10 and the floors were hot.
05-30-2012, 03:00 AM | #11 |
someone on here found a product to add to your own paint or bed liner. I think it was hollow ceramic beads.. creates a layer for a heat barrier...
found it ... http://www.hytechsales.com/insulatin...additives.html Last edited by mcmlxix; 05-30-2012 at 04:12 AM. Reason: added link |
06-24-2012, 07:21 PM | #12 |
The top that came with the truck was hammered, so I found this grey one in excellent shape as a replacement. My 14 year-old in the background will be the liucky driver on this when it's done (if he behaves).
Getting ready to refinish the top. Need to decide if I want smooth or textured like original. |
06-24-2012, 07:26 PM | #13 |
Finally getting the body ready... Adding a few more pics...
Found some old brass filler in a couple places. For the most part I'm, happy with what we found... pretty virgin. I was nervous for a bit. |
06-24-2012, 07:28 PM | #14 |
Still not 100% on the color scheme.... down to dark silver/light grey metallic (not as dark as this one) with a black top or staying with blue (adding a metallic, like a "Lemans Blue" and a white top. Similar to original.
I need to decide pretty quick... Opinions? |
06-24-2012, 08:31 PM | #15 |
Any idea how to get this thread where it belongs... over to the build section?
06-24-2012, 08:35 PM | #16 |
VA72C10
nice top! Moved it for you....
06-24-2012, 09:07 PM | #17 |
06-26-2012, 06:34 PM | #18 |
My vote is for the blue/white combo but I'm biased... I feel like blue is less common and the white top keeps the "vintage" look.
Posted via Mobile Device |
06-27-2012, 10:23 AM | #19 |
I like the dark grey. that k5 is killer looking!! hmm ideas....
07-24-2012, 11:44 PM | #20 |
Decided on the blue. Corvette Nassau blue in fact. I originally wanted the Jetsream Corvette blue, but at $1k/gal I passed. Nassau is $350/gal... better.
Coming along. Ordered all of the roll cage material... removed the 2 fuel tanks (original & PO added) - installed new 31 gal fuel tank, refinishing the top, tilt column, ceramic headers, new windshield, new bumpers, powder coating hinges, mounts, core support... new urethane bushings, all new nuts and bolts, bought new seats... should be in the booth in 2 weeks! |
07-25-2012, 12:27 AM | #21 |
Registered 1971 K5
Looking really good.
08-10-2012, 09:40 PM | #22 |
Soon all you hard work will be rewarded.
03-07-2013, 11:21 AM | #23 |
Got crazy the other day and pulled the frame off... Yep full frame-off restoration! I'm certain I've opened a can of worms, but with it being so close I just went for it. Frame is back from powder coating.
Posted via Mobile Device Posted via Mobile Device |
03-07-2013, 01:54 PM | #24 |
lookin good,, keep em comin
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
03-07-2013, 02:09 PM | #25 |
KEEP ON TRUCKIN'
It's going to be a beautiful truck. That should be some good incentive for your young-un to mine his p's & q's.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
