Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-28-2012, 03:48 PM   #1
Shaun1162
Shaun1162's Avatar
Radio off when I first start my truck?
Sorry if this question has been asked, but I can't seem to find anything to answer it...
So when I first start my truck, my radio is completely dead. No matter what you do (turn on/off, play with the volume, etc.) it won't do anything. After probably 5 minutes, it starts to come in very quiet and fuzzy, and then after another 5 or 10 minutes the radio will come in fine.
Is it something inside of the radio going bad? Or maybe the speaker (Not stock.. Got it at a junkyard)?
Thanks in advance for the help.. It's driving me nuts!
- 2010 Silverado
- 1984 Chevy M1028 (K-30)
- 1969 Chevy C-30
- 1933 Ford Stock Car
Shaun1162 is offline   Reply With Quote
Old 05-30-2012, 02:35 PM   #2
ole dollor
ole dollor's Avatar
Re: Radio off when I first start my truck?
i would try hooking up another speaker to the radio, the speaker could be bad, you could just lay it in the floor and hook the wires up and see if it starts working, if not, the radio needs to be worked on or replaced, dash mounted speakers are prone to sun damage....hope this helps...
ole dollor is offline   Reply With Quote
Old 02-18-2013, 03:03 AM   #3
Jdhitch
Jdhitch's Avatar
How hard is it to remove the speaker? The sound from my radio is so quiet I can barely hear it. Could this be the antenna causing the low sound?
Jdhitch is offline   Reply With Quote
Old 02-19-2013, 12:03 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
Hi are you using the stock type plug in
I've seen the copper strips in them warp/break and not connect
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-23-2013, 05:37 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I had a pioneer HU that used to do the same thing towards the end of its life. The front panel would light up and seem to work, but no sound or response to controls. The control board for the unit was slightly warped (much like when you overheat a computer processor board). When cold it wouldn't connect, but when the truck got hot behind the dash it would flex enough to make the connections again. I just ended up replacing it tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
