Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 06-02-2012, 03:38 PM   #1
Pro Performance
Pro Performance's Avatar
June Special: Pro2 Air Management Kit
This month we will offer our Pro2 Air Management kit for $1,188.00, which is a savings of $62 on an already great price. This system includes everything you need to install a quality air management kit onto your C10, and has everything to plumb right into you air bags. We did not exclude anything, and this even comes with gauges, which most kits out there don't include, but is definitely needed.
This is a complete 200 PSI air source for your air suspension vehicle, and ready to plumb into your bags. We took all the guess work out of selecting the right air source for your air suspension. Our Pro2 kit has dual VIAIR 444C compressors filling the 5 gallon aluminum tank, and includes all necessary fittings needed to correctly setup your air source. We opted for the AccuAir VU4 as the manifold in this system, due to it's simplicity. This system will include the switch box and gauges needed inside your cab to monitor pressure at each corner of your vehicle. You can select the option AccuAir SwitchSpeed controller.
Pro2 Air Management Kit Includes:
2 - VIAIR 444C Chrome Compressors (200 PSI)
1 - 5 Gallon 200 PSI Rated Aluminum Tank (6 Port)
1 - AccuAir VU4 Valve Block
1 - AVS Arc 7 Control Box
2 - VIAIR 220 PSI White Face Gauges, Illuminated
1 - 165/200 Sealed VIAIR Pressure Switch
1 - 250 PSI Safety Valve
2 - VIAIR 40A Relays
1 - 60A Inline Fuse Holder
1 - Drain Valve
1 - 1/4" NPT Street Tee
1 - 50 Ft. of 3/8" DOT Approved Air Line (Bags)
1 - 75 Ft. of 1/4" DOT Approved Air Line (Gauges)
4 - 1/4" Hose to 1/4" MNPT
2 - 1/2 MNPT to 3/8" Air Line PTC Fittings, DOT Approved
4 - Bag Fittings (Select size under options)
Just enter coupon code "June" to order online and get the discount.
Pro Performance is offline
Old 06-04-2012, 03:06 AM   #2
5Skware
Re: June Special: Pro2 Air Management Kit
So this has everything that I would need for a complete setup except for 4 bags? Looks like a pretty good deal!
5Skware is offline
Old 06-04-2012, 09:44 AM   #3
Pro Performance
Correct, except 4 bags and your suspension brackets and components. This is the complete air management side of your air ride suspension.
Old 06-04-2012, 06:01 PM   #4
5Skware
Any deals that add some bags? Specifically re7's? Or 7s and 8s? Thanks!
5Skware is offline
Old 06-04-2012, 07:04 PM   #5
Pro Performance
Sure! If you purchase the kit, I can add Slam SS7's for $75 Ea. ($300 for Set of 4)
Old 06-05-2012, 01:27 AM   #6
5Skware
PM sent!
5Skware is offline
Old 06-06-2012, 08:21 AM   #7
The_BullDog
The_BullDog's Avatar
PM sent!
The_BullDog is offline
Old 06-06-2012, 06:21 PM   #8
Pro Performance
PM's Returned
Old 06-13-2012, 11:26 PM   #9
Pro Performance
Thanks for the orders guys!
This is a great kit that has everything you need. Takes all the guess work out of putting together an air management kit.
Old 06-20-2012, 02:11 AM   #10
Pro Performance
Still have this deal going through the end of the month. We also have a Porterbuilt deal happening also. When grouped with that, you can get some real savings.
Old 06-27-2012, 01:36 AM   #11
Pro Performance
This special ends on Saturday, along with out Porerbuilt special.
Old 06-04-2013, 08:01 PM   #12
Pro Performance
Let's get this special going again for June. Let us know if you have any questions at all. We also added a coupon for easier ordering right online.
Old 06-05-2013, 08:43 AM   #13
RoadRat
RoadRat's Avatar
By chance is there any porterbuilt specials going on like last year?
RoadRat is offline
Old 06-05-2013, 10:28 AM   #14
Pro Performance
Yep, there sure is....
http://67-72chevytrucks.com/vboard/s...d.php?t=527564
Old 06-27-2013, 01:22 PM   #15
Pro Performance
Pricing still good until tomorrow by calling in, or can order online through Sunday. Thanks guys!
Closed Thread
accuair, air management, bagged, kit, viair
