Old 06-07-2012, 01:01 PM   #1
Frijolito1988
1968 AC Help.
Hey guys, I am getting ready to drop a 350 SBC on the 68 , the 68 truck has AC , but the small block does not have the compressor .
Right now the engine has the alternator on the passenger side , from picturs I have seen, the alternator goes on the driver side and compressor on the passenger side for these trucks ? Can anybody post up pics of your stock AC. Thanks!!
Frijolito1988 is offline   Reply With Quote
Old 06-07-2012, 01:10 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: 1968 AC Help.
You can probably find the correct alt. brackets real cheap and the 7 piece ac brackets fairly cheap on the parts board.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 06-07-2012, 01:27 PM   #3
Frijolito1988
Re: 1968 AC Help.
Thanks! I am not in a rush to hook up all the AC stuff, do you guys recompensed putting the compressor and switching the alternator before i install the engine or that is a pretty basic thing and can do when the engine is already mounted ?
Old 06-07-2012, 01:33 PM   #4
john
member #16
john's Avatar
Re: 1968 AC Help.
The difference is the long and short water pumps. The long pump setup is a pass side alt, and the short is driver side alt. they use all different pulleys and brackets between the two types.
john is offline   Reply With Quote
Old 06-07-2012, 01:46 PM   #5
Frijolito1988
Re: 1968 AC Help.
Oh, dint know that. Can you guys tell if this is a long or short pump ?
Old 06-07-2012, 02:15 PM   #6
john
member #16
john's Avatar
Re: 1968 AC Help.
I can't tell from pic, but heres a diagram.
Old 06-07-2012, 02:31 PM   #7
Frijolito1988
Re: 1968 AC Help.
Thanks! So pretty much if I want to run a stock bracket for my ac compressor. I have to get a short water pump, compressor bracket, alternator bracket that are all for a 67-68 small block chevy right ? The other pulleys stay the same ?
Old 06-07-2012, 02:45 PM   #8
Frijolito1988
Re: 1968 AC Help.
also as far as the compressor brackets and alternator brackets, anybrackets from a smallblock chevy 67-72 should be good to go right ?
Old 06-07-2012, 03:51 PM   #9
john
member #16
john's Avatar
Re: 1968 AC Help.
Yes as long as your heads have the acc. holes which it looks like they do.
Old 06-07-2012, 03:59 PM   #10
Frijolito1988
Re: 1968 AC Help.
Thanks bud. Really appreciate your help.
Old 06-07-2012, 08:47 PM   #11
100%Chevy
Re: 1968 AC Help.
You don't need the accessory holes in the heads if you use the original mounts with the short water pump.
Here is my 68,C-10 without the compressor mounted.
Most 60's car or truck mounts will work.
Uploaded with ImageShack.us
Mike./
100%Chevy is offline   Reply With Quote
Old 06-08-2012, 05:25 AM   #12
JCD
JCD's Avatar
Re: 1968 AC Help.
I have this alternator set up on my 1972 which is odd, as my truck originally came with AC.
Yours was likely added as well, as it looks like you're missing the bolt hole for the bracket on the top..
I believe my motor to be a later year, as it's black, and the oil dip stick is on the passenger side.
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 08-14-2014, 12:27 AM   #13
botmfedr1
botmfedr1's Avatar
Re: 1968 AC Help.
Correct me if i am wrong....but i don't think the 7 piece bracket is original for the 1968....
here is what i believe you should have. You might want to do more research.
the pic with the pump attached is a pic i got from Wes, at ClassicHeartbeat.com in Olympia, WA...
botmfedr1 is offline   Reply With Quote
Old 08-14-2014, 09:08 PM   #14
100%Chevy
Re: 1968 AC Help.
Mike./
The picture I posted is not the original brackets!These are from a 65/66/67 Impala.And,the evaporator is from a 73/87 truck.I was converting my truck to the orifice tube expansion system when this pic was taken.
I didn't mean to miss-lead anyone.I just forgot to post all the information.
But everything does work.
Mike
Old 08-16-2014, 04:33 AM   #15
luvbowties
luvbowties's Avatar
Smile Re: 1968 AC Help.
If your fingers will go between the water pump and engine(going in from top), it is the long one. So, yours looks like the long one.
S
luvbowties is offline   Reply With Quote
