Old 01-30-2002, 08:50 AM   #1
fade941
Question Motor mount towers
I am getting a 64 Chev. It originally had a 6 cyl but has no motor now. Where can I get the correct towers to put a 350 in it?
69 C10 SWB/68 Camaro
There is nothing like doing it yourself..
Allen, Tx. just N. of Dallas.
fade941 is offline   Reply With Quote
Old 01-31-2002, 11:19 PM   #2
67_SS396
Post
I think I still have a set of sb mounts in the garage from my '65. I will look and let you know. I live just down the road from you in Sachse and am through Allen a couple times a week.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 02-09-2002, 11:27 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
i know the frames are the same.... so shouldnt a set off a 67-72 work?
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-12-2002, 03:40 PM   #4
bbs1965
Open Sundays 10 till 10
Post
no they are different
parts for sale always
30 minutes south of Dallas on I35
WWW.BBSAutoSalvage.com
bbs1969@direcway.com
bbs1965 is offline   Reply With Quote
Old 02-21-2002, 12:53 AM   #5
turbo
Post
I have a 65 short-bed step-side that came with a 6-clyinder when I put a 350 in it all I did was moved one motor mount so that it lined up with the other.Your frame should have holes near where the motor mounts are.The frames are fatory drilled for I6 or v-8 engines.
1965 CHEVROLET C-10 SHORT-BED STEP-SIDE W/ 409 AND A 4-SPEED
1966 PLYMOUTH BARRACUDA W/ 360 PLYMOUTH AND A 727 TORQUEFLITE
1983 PONTIAC FIREBIRD W/ 350 CHEVY AND A 5-SPEED
1989 CHEVROLET SILVERADO W/ 350 CHEVY AND TH-700R-4
turbo is offline   Reply With Quote
Old 02-21-2002, 12:56 AM   #6
turbo
Post
Any v-8 or I6 motor mounts from 1960-72 should work.My 350 came out of a 69 3/4 ton chevy truck I was able to use the motor mounts for the 69.
Old 02-21-2002, 09:19 AM   #7
u2slow
Web Wheeler
u2slow's Avatar
Post
63-72 SBC towers should work. 60-62 used a front mount instead.
I6 mounts *may* work if you move them around, but they are different. You may run into some alignment problems that could affect various linkages, driveshaft angle/length, etc.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 02-21-2002, 02:59 PM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
well i have a set of v8 motors mounts off a 69 if anyone is interested
My Truck pictures
64ImpalaSS 327
