![]() Join Date: May 2012
2'' body lift
anybody ever done a 2'' body lift on there 67-72 c10? need to see some pics.
Re: 2'' body lift
I think you mean k10 because c10 is 2wd btw.
Re: 2'' body lift
Pretty cheap to just do a spring lift on these trucks, not sure I would do a body lift myself.
Posted via Mobile Device |
Re: 2'' body lift
I am quite sure what my truck is...I am doing a body lift on my 2wd to allow room for the 31" tires I put on it..it is a work truck and i plan on loading it down.
I am just wondering about how the bumpers will line up w a body lift.. |
Too many projects
Re: 2'' body lift
The bumpers stay where they're at, so 2" below where they should be, looking awkward. I hate body lifts as they have more problems than benefits, as you will change the relationship of the steering column to box (stock is a straight line) and shifter linkage, fan shroud to fan clearance, etc.
If you want to load it down, don't do a body lift just swap out the rear coils for a stiffer set or if leaves do an add a leaf to the back. Heck even stock springs have to be stronger than the worn out originals. I plan on putting air over leaf on the back of my K20 to compensate for trailer weight on stock worn out springs (but it rides nice!).
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
Re: 2'' body lift
here are the before pics
Re: 2'' body lift
Shoot that looks like its been lowered to me. Like was said some new springs might do you better.
Re: 2'' body lift
helpfull info LOWROLLER.you may be right..you got me reconsidering my plan..I like to keep things looking right. I dont want my truck looking freaky with the bumpers out of whack
I may just replace the rear coil springs..there the ones that came on the truck. I put new springs on the front but it still looks low. |
Re: 2'' body lift
This is my truck with the 31" tires..I want more fender clearance.
Re: 2'' body lift
Have you looked around on http://67-72chevytrucks.com/vboard/s...d.php?t=449588 some of those trucks even 2wd sit pretty high from the factory.I think its been lowered or the springs have sagged over the years.See if the 3/4 ton springs are a different part number then the 1/2 ton if so they will give you some lift.
![]() Join Date: Mar 2012
Re: 2'' body lift
that has definitely been lowered in some way. If you are going to load it down def don't do a body lift, but that is just me
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 ![]() |
Re: 2'' body lift
You couldn't pay me enough to use a body lift.
#13 |
Re: 2'' body lift
I got my body lift done except for the radiator support. When I got ready to replace the mounting pads I found out my core was trash. I am looking for a replacement. I dont know what the big deal was, I did not find it to be to big of a pita and I really like the way it looks. I will get some pics when I find a replacement core support.
#14 |
Re: 2'' body lift
As long as you are happy with your truck that is all that matters. Anxious to see how it turned out!
#15 |
![]() Join Date: Apr 2000
Re: 2'' body lift
kinda funny i had 31`s on my truck before and its a stock 1/2 ton and not issues..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#16 |
Re: 2'' body lift
I got my new/used radiator core support today. One of the advantages to working at WalMart is you get to see lots of people who have old truck parts. Talked to a man and he sold me a core support for a cool 20 bucks. It had a little cancer on the right side bottom but otherwise in good shape. got it cleaned up and painted today and ready to go in tomorrow.
#17 |
Re: 2'' body lift
my doner core support I payed 20 $ for
#18 |
Re: 2'' body lift
I got my core support in today. I think it turned out really nice.
#19 |
Re: 2'' body lift
Got my head light buckets in today as well as radiator shroud fitted and trimmed and got my radiator put in.
#20 |
Re: 2'' body lift
Old I know, but really interested in outcome and have a question or two. Pm me if willing to share.
Leadbelly |
#21 |
BlahBlahBlah
Re: 2'' body lift
The OP hasn't logged in for two years, hopefully he still lurks for ya.
