Old 06-20-2012, 06:56 PM   #1
osaltyone
osaltyone's Avatar
Trans lines
What did you guys do for the trans lines? I have the originals in there now stopping fluid from leaking and though I would use them, but it is going to be a pain to try and run them down my frame to the radiator with the drop memeber in there. They also look like they will be really close to the exhaust when ran.
I have a 4L60e
osaltyone is offline   Reply With Quote
Old 06-20-2012, 09:19 PM   #2
Dustytrix
Re: Trans lines
I bought new ones but mine had a standard tranny before, anyway it will be hard to do it with engine in the bay, I bent mine to fit the engine before it was installed.
Dustytrix is offline   Reply With Quote
Old 06-20-2012, 09:21 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trans lines
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-20-2012, 09:34 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Trans lines
I hit the LAPS and got some coated line and put the bender to work. Cost $10 and a little bit of time. I don't think you'll find an off-the-shelf line to work with the DM...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-21-2012, 05:41 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Trans lines
I have a 4L80e but the factory runs the hard lines next to the block and has a flex section before it connects to the radiator. I bought new lines from gmpartsdirect.com along with a bracket that bolts to the block and a few clips to keep them from moving around. I just ordered some 3/8 compression to -6AN fittings and will cut the hard line at the front of the motor and run the rest with AN to a trans cooler.
As far as heat goes, if GM ran it next to the block and under the exhaust manifold it shoould be good to go.
Rich
1972 K5 Blazer CST Click HERE
Old 06-25-2012, 01:51 PM   #6
pwtr02ss
Re: Trans lines
I did -6 braided line
pwtr02ss is offline   Reply With Quote
Old 06-25-2012, 06:19 PM   #7
osaltyone
osaltyone's Avatar
Re: Trans lines
Thanks guys! You've been a lot of help. I started working with the stock lines to save $, but kinked one up even with the tube bender, so I called a mobil hydraulic guy and he came out and made braided lines with all the fittings. Wasn't cheap, but didn't have to wait for shipping. I'll post some pics tonight.
Old 06-25-2012, 07:16 PM   #8
youseez
Re: Trans lines
I am running an after market billet trans cooler, mounted to the frame under the passenger door, with steel braided hose and AN fittings. Had the radiator shop plug the holes in the radiator.
youseez is offline   Reply With Quote
Old 06-26-2012, 08:28 PM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Trans lines
Heatsink style?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-27-2012, 12:31 PM   #10
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Trans lines
What about just running the metal lines down the frame like the turbo 350 to the radiator trans cooler?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-27-2012, 01:05 PM   #11
chevy72blu
chevy72blu's Avatar
Re: Trans lines
That was my plan also - for both fuel and trans. I havent bent lines before, but it doesnt seem all that complicated with the right tool.
chevy72blu is offline   Reply With Quote
Old 06-27-2012, 02:04 PM   #12
osaltyone
osaltyone's Avatar
Re: Trans lines
Here are the lines they guy built to run to the C10 radiator
Old 07-29-2012, 02:48 AM   #13
CEE1NG_RED
Re: Trans lines
Where did you get these from??? I like how the lines are simple and not too colorful.
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 07-31-2012, 05:04 AM   #14
mcmlxix
mcmlxix's Avatar
Re: Trans lines
See above, he had a mobile guy build the lines...
Rich
Old 07-31-2012, 02:17 PM   #15
osaltyone
osaltyone's Avatar
Re: Trans lines
Yea, sorry. I had a guy come out and custom bend them. Just searched CL and found a company. Was just over 100 for the 2 lines, so not cheap by any means, but probably about the same if you bought -AN stuff.
Old 07-31-2012, 05:29 PM   #16
Daaaanz67
Re: Trans lines
Those are jic fittings same as an fittings most hydrolic shops carry them. I use them on my p/s
Daaaanz67 is offline   Reply With Quote
