Old 02-09-2002, 09:42 AM   #1
Shorty Cox
Post Power Steering Conversion
I purchased a steering gearbox, pump, and the lower portion of the steering column off a 1976 chevy 1/2 ton. I want to install it on my 1964 chevy 1/2 ton. I know Classic Performance sells a kit, but has anyone ever done this conversion without a kit? If so, what problems did you encounter?
Shorty
Shorty Cox is offline   Reply With Quote
Old 02-09-2002, 06:20 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
the "kit" they sell is a bracket. which is fairly inexpensive
anthor option is to heat the frame up with a torch than hit it HARD with a ball pen hammer to "dimple" the frame like on later model trucks.... than 1 or two of the factory holes should line up with the steering box..... bolt those in and drill out the other ones
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-09-2002, 06:21 PM   #3
golds'64
Post
Shorty,
I haven't done it personaly,But this might give you some head-up info.http://www.classicperform.com/power6066.htm
golds'64 is offline   Reply With Quote
Old 02-11-2002, 01:25 PM   #4
jamiew
Post
The conversion kit is easy and hard to get wrong. There are actually two plates in the kits, a plate that actually supports the gearbox, and an inner plate which acts as a frame brace so that the new gearbox will not cause any frame warpage. I did my 64 pickup and it was just a bolt on procedure. Bolt on the plate using the original holes, then drill out the new holes using the outer plate as a guide. I wouldn't heat the frame because it might weaken it. You wouldn't want the frame to break while taking a hard, fast curve but that's my opinion.
jamiew is offline   Reply With Quote
Old 02-11-2002, 01:29 PM   #5
jamiew
Post
I would also get the rest of the front end of the 76 1/2 ton and bolt it up to the 64 frame. It is almost as simple as putting on power steering and you will have disc brakes. That's what I did to my 64'. Now if I could only finish up the rest of it......
Old 02-13-2002, 05:38 PM   #6
Shorty Cox
Post
Thanks guys. I've thought about the kit, but $95.00 is just to much for 2 plates and bolts. However, i do realize they put in the engineering. I read a message on the net once where a guy installed power steering without the use of the kit. Just can't find that site.
Jaminew, I've heard one can swap out total frontends like that. I wish to retain the 6 lug wheels. (Yes, there is also a kit for that). When you did yours, did you change out the master cyclender to power?
Shorty
Old 02-14-2002, 04:58 PM   #7
jamiew
Post
shorty,
Well, I plan to but I haven't yet. To tell the truth, I have just started to put the body back onto the frame. I have read that a 69-72 will almost bolt right up, but the actuator rod will have to be modified to work with the booster. Oh, and Chevy Duty has a kit for 59.95 for the power steering conversion. When I get to the point where I am installing the booster onto my 64 I'll let you know how the installation goes.
jamiew
Old 02-25-2002, 07:14 PM   #8
Shorty Cox
Post
OK, here is the scoop. I just finished bolting up the power steering box from a '76 chevy pickup onto my '64. I'm not finished, but you don't need a kit. Just take good measurements and bolt it on.
Old 03-09-2002, 11:22 PM   #9
Shorty Cox
Post
Guys, I completed the power steering conversion today. Nothing to it. Utilize teh forist lower mounting bolt hole from the original steering box. That is you begining point. Take good measurements, and match the measurements. You will need to fabricate spacers to mount the later model sterring box as it is not flat on the mouting side. The pitman arm will bolt right into the drag line. When you purchase the steering box, also get the first section of the the steering shaft. This it the collapsible portion of the shaft. Cut it off about 6" above the rag joint. the inside dimeter of the tube is 3/4", that same as the OD of the stock steering shaft. Cut off about 6" of the stock shaft about 6" above the rag joint. it will slip down into the later modle shaft you have cut off. Use the trial & error method to determine the exact length needed to reach teh steering wheel. once you have done that, weld the rag joint to the stock shaft. Put the shaft into the column first, bold on the steering box, slide the rag joint into place, bold on the pumb, hook up the lines, and you are in business.
Easy.......
