Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-22-2012, 11:36 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
600HP BBC Budget Build
Do it. Ignore the fuel system and build the rest. Tell me what you'd do. One day I'd like to put it in a 81-87 C30 Reg cab just for the hell of it.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-22-2012, 12:06 PM   #2
El Campo
El Campo's Avatar
Re: 600HP BBC Budget Build
http://www.carcraft.com/techarticles...d/viewall.html
Car Craft already did it and made 707 Hp for $6700. It could probably done for cheaper than that too.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 06-22-2012, 02:40 PM   #3
thirdstreettito
Resident of Here
Thanks! More input appreciated too
~Bradley~
Miss having a truck
Old 06-22-2012, 08:07 PM   #4
C-10 simplex
If big blocks come with forged cranks then i would just add nos fogger system for about $900.
C-10 simplex is offline   Reply With Quote
Old 06-22-2012, 11:20 PM   #5
thirdstreettito
Resident of Here
Lol I should've mentioned, no nitrous.
~Bradley~
Miss having a truck
Old 06-24-2012, 02:23 PM   #6
thirdstreettito
Resident of Here
Ttt
~Bradley~
Miss having a truck
Old 06-24-2012, 04:06 PM   #7
mightymouse
mightymouse's Avatar
i didnt think there was a budget 600 hp motor of any kind.......jw
mightymouse is offline   Reply With Quote
Old 06-25-2012, 04:52 PM   #8
C-10 simplex
What is the budget limit?
Old 06-26-2012, 12:30 PM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Here's what I did - and if it doesn't hit 600hp, it will at least scare it, and I tried to be budget conscious in choosing parts which is usually not in my nature...
Ported Edelbrock #61459 Marine heads (used off eBay for $1000), I had them flow benched so I could order a custom cam - 331 cfm intake/250 cfm ex @ .600" lift. chambers cc'd @ 109. Heads came with slightly used Crower springs, Comp pushrods, & Crane aluminum roller rockers and ARP head bolts.
Traded some parts for a used 870cfm Holley street avenger.
New Edelbrock RPM air-gap intake & Victor Series water pump from Summit
.060" over 2 bolt '78 3/4 ton chevy truck 454 block (I already had the motor)
Stock steel crank, .010/.010, resized stock rods ARP studs in block, ARP bolts in the rods. Decked block, set pistons .005" in the hole.
SRP forged small dome pistons, 10.8:1 compression with .039" head gasket.
(spent a little extra for nice forged pistons)
Custom ground hyd roller cam by Chris Straub, 245*/248* @ .050", .646" lift (spent some money for a nice cam/lifters/custom pushrods)
Cloyes Hex-A-Just Billet double roller timing set & matching Cloyes Quick Button timing cover.
DUI custom curved distributor & DUI LiveWires plug wires.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-26-2012, 09:52 PM   #10
thirdstreettito
Resident of Here
Nice! About how much did that hit your wallet?
And guys, I basically mean the cheapest way to hit 600hp.
~Bradley~
Miss having a truck
Old 06-27-2012, 09:13 AM   #11
djracer
djracer's Avatar
Bosshogg's setup looks pretty solid.
I hope to crank my son's truck this weekend and it won't be quite that strong but very solid on a budget. 781 open chamber oval ports over a stock type closed chamber dome. I am not a big fan of a hyd cam but it came with the motor. It has a performer rpm cam, lifters and intake with a 650 double pumper. Backed up with a built turbo 400 and a narrowed 9 inch.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-27-2012, 10:26 AM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
Mine was just a tick over $6k, with the machine work and assembly. Had I just gotten it machined and screwed it together myself, I could've save a couple hundred bucks, but I don't claim to be an engine builder and didn't care to experiment on this one. I'm sure it can be done for cheaper, but I wanted a custom roller cam to really take advantage of the heads and get a really wide powerband.
Adam
Old 06-27-2012, 02:17 PM   #13
69GMC910
MOTORHEAD!
69GMC910's Avatar
http://www.vortecproperformance.com/...binations.html
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 06-27-2012, 03:32 PM   #14
thirdstreettito
Resident of Here
Originally Posted by 69GMC910 View Post
Are those prices for real!?? That's practically free compared to other companies. Hmm, probably buying one of those istead of building.
~Bradley~
Miss having a truck
Old 06-27-2012, 03:52 PM   #15
69GMC910
MOTORHEAD!
69GMC910's Avatar
Yes, i have a 707hp AFR headed 496. Pump gas 9.9 CR, small hyd roller... Was under $9000 when I bought it. The AFR heads up the price quite a bit over the cast heads. I have yet to install mine, but I can already guarantee I will be a return customer!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 06-27-2012, 06:26 PM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
thirdstreettito - check out www.chevelles.com in the 'performance' section. 'Vortecpro' is Mark Jones over there (same person 69GMC910 ordered his motor from). Tons of positive feedback on his engines there. Also lots of other good Big Block advice on combos, parts and what not.
Adam
Old 07-16-2012, 11:17 PM   #17
C-10 simplex
Never mind---i just re-read no nitrous.
