06-22-2012, 05:03 PM | #1 |
70 Monte Carlo 12 bolt in a 65 C10
I found a 70 Monte 12 bolt 411 Posi. Anything major need done to fit it under my C10. I figure trailing arm brackets and a new Panhead bar kit should be all. Maybe shock mounts moved. Trying to get back to 6 or 5 lug. I currently have a Dana 8 lug as it is set up as a pull truck. Thanks for any feedback. I think the WMS to WMS on the Monte is 61" so it should fit nicely
06-22-2012, 05:17 PM | #2 |
Re: 70 Monte Carlo 12 bolt in a 65 C10
Check the width, but it should be straightforward.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
06-22-2012, 05:36 PM | #3 |
you know the monte bolt size is 4 3/4 and the truck is 5" rite ?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
06-22-2012, 06:03 PM | #4 |
Yes, Thanks I do want the 4-3/4 pattern, putting 12" Billet Specialties Lites on it. If I go disc on the rear is there a donor rotor and mounting plate I can use. I also have a set of 85 1/2 ton spindles for the front and somebody told me I can use camaro rotors with the 4-3/4 pattern. Any ideas...
06-22-2012, 08:40 PM | #5 |
Never Ending Projects
Don't quote me but I thought someone made a disc kit that used the original drum brake spindles that use the Camaro (or late B body) rotors. That was the downfall of the kit, it gave you the pass. car bolt pattern. For you it would be a benefit.
Wish I could remember who it was... maybe Fat Man or Speedway???
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
