Old 06-26-2012, 07:15 PM   #1
schmittyjr
70-72 c20 Dana 60 w/trailing arm/panhard mount
Just curious to see if the trailing arm mounts are in the same location as the 12 bolt in a C10. Also is the panhard bar the same as in the C10.
schmittyjr is offline   Reply With Quote
Old 06-26-2012, 11:42 PM   #2
Captainfab
60-66 Nut
Re: 70-72 c20 Dana 60 w/trailing arm/panhard mount
The trailing arm mounts should be in the same location. The panhard bar should be the same as typical on a '65-'72 12 bolt.
Old 06-27-2012, 06:18 PM   #3
schmittyjr
Why thank you sir.
