Old 03-16-2002, 11:00 PM   #1
Joachim
Carolina Cajun
Question 66 VIN Decoder
About to acquire a 66 C10. Opening VIN nubers are: C1546BXXXXXX. Anyone have link to a site with the decode info or able to provide the info? Have decoder for 67/68 and comparison goes to a C=4x2, ?, ?, ?, ?, B=built in Baltimore. Want to see if what is there is OEM or modified.
Thanks.
Joe
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 03-25-2002, 12:11 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
C1546BXXXXXX
You are right on the first digit;
C= 2 wheel drive
15= 1/2 ton
4= Pickup
6= 1966
b= Baltimore
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-25-2002, 09:07 AM   #3
Joachim
Carolina Cajun
Talking
Longhorn, thanks for the information and confirmation. Side question. Where is the VIN plate located. I drive a 68 and it is in the door frame. On the 66 I'm looking at, I found a similar plate on the kick panel on the driver side, but it didn't have the VIN, just model codes and paint codes and other general info. Also found a paper glued on the glove box door. Don't remember if the VIN was on it, but it had OEM info also. Where else to look?
Joe
Old 03-31-2002, 01:03 AM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
Post
The vin plate should be on the left hand roof rail. That is what the book says. I have a 66 C30. My vin plate is gone. There is also some vin information on the frame which is stamped lightly and located usually in hard to get to locations. I believe one place is under the cab on the frame rail. I haven't checked for the one on my truck yet because it is unique enough that I'm positive it is what the title identified.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
79 Chevy 4X4 (Tom's old truck)
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 03-31-2002, 12:59 PM   #5
Joachim
Carolina Cajun
Thumbs up
Thanks for the tip ddsmith. I go to pay for it and pick it up on Tuesday. I'll take another look then. Found a "Model" number info plate on the driver side kick panel, no VIN there. Also found a OEM sticker on the inside of the glove box door, still no VIN there either. I'm confident that it is what the owner says it is, but just want to confirm.
Thanks again
Joe
Drivin' my Wife to the Looney Bin in my 68 C10!
Old 04-08-2002, 12:35 AM   #6
Longhorn Man
Post
Sorry, I don't frequent this board much, I hang out on the '67-'72 one all the time.
Acording to my book, your vin plate should be on the left inner cowl.
Did you get your rig yet?
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
Old 04-08-2002, 09:02 AM   #7
Joachim
Carolina Cajun
Thumbs up
Thanks for the info. Brought it home last wednesday. Found the VIN plate, a little 1" by 3" plate, in the top of the cab door frame. There is a model number plate on the driver kick panel and a paper glued in the glove box lid that are still there. Owner also left me the original sales invoice from 66.
I mostly hang out on the CT boards. See your input there often. Any suggestions as to what prep work to do prior to starting it for the first time? Plan to replace/change out all the oil, plugs, wires, gas etc. Any thing else to consider?
Joe
Old 04-12-2002, 11:33 PM   #8
Longhorn Man
Post
For just cranking it up, not driving, I would do as you are saying there, but I would also prime the engine...to ensure good lube on start up. (You have bumped it over to make sure it isn't locked up, right??) After priming it, I would put on new cap rotor, plugs, wires, fuel filter, and a few gallons of real good gas. (high detergent, high octane) Then disable the coil, and crank it a few seconds, listning for death noises. If all sounds good, plug in the coil, and let her rip.
I would drain the oil after 15 min or so of running it, also, don't let it idle durring the first 15 min or so too, basicly, it's like braking in a new motor, but instead of machine shop stuff your flushing out, it is rust.
[This message has been edited by longhornmail (edited April 21, 2002).]
