Old 07-08-2012, 04:50 PM   #1
Nothinghead
Nothinghead's Avatar
Would this work?
http://www.easyexport.us/carfinder/v...=4c05538a458b1
what would be stopping me from taking this vehicle and putting it's 6.0 and transmission into my 79 Blazer?
I am trying to learn what I would need to swap to a LSX. I would like to buy a salvaged vehicle like this one is and then just transfer everything over.
What stuff would swap and what would I need to buy in addition to the vehicle? I know there are things like the harness that need to be modified, and the ECM needs to be programed, but are there anything else I should get?
I am tired of the 6 MPG and I think this would be a good swap and a way to fix the mileage.
79 Blazer 350 TH350 part time 4wd Sold!
86 GMC 1 ton something...
Nothinghead is offline   Reply With Quote
Old 07-08-2012, 08:07 PM   #2
Dustytrix
Re: Would this work?
Will the hybrid engine work? Check into that, I don't know but if it will looks like a good start to me.
Dustytrix is offline   Reply With Quote
Old 07-08-2012, 08:17 PM   #3
Nothinghead
Yeah, I saw the hybrid thing after I posted. I meantime more along the lines of a salvaged vehicle in general. Hybrid would be cool though too.
Old 07-09-2012, 01:13 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I think the engines are actually the same; IIRC the hybrid portion is attached to the trans of the transfer case or something like that.
Getting a salvage vehicle for the engine is fine as long as it wasn't a flood/storm or fire recovery.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-09-2012, 10:37 AM   #5
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Pretty sure the engine is the same, but the electronics are going to be different..... Swap it all and make your truck a hybrid?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-09-2012, 10:41 AM   #6
Nothinghead
So it is that simple then, just swap all the stuff? I am not hung up on it being a hybrid, I just want the modern drive train.
Old 07-09-2012, 12:18 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Everything besides wiring would be pretty much standard with the rest of the LS swaps. The engine is actually called a 6000 LFA and runs a slightly higher compression, variable valve timing and active fuel management.
You would probably want a different trans, as the Hybrid system basically is PART of the trans. There is an electric motor that "helps".
The engine is also whats called an "atkinson cycle" engine, which apparently has different intake valve events, meant to be really effecient but develops way less torque because the electric motor would "help" that portion. The engine also has stop-start so it has a REALLY neat oil pump and better cylinder wall oiling.
I say you build the first hybrid 6.0 in one of these....prove to the stupid hippies that we are "green".
Old 07-09-2012, 12:19 PM   #8
Nothinghead
It would certainly make my green minded (hippy) wife happier.
If the hybrid guts really would just need to be fit in there and that's it, I may give it a shot if I can get the vehicle for cheap.
I do like torque though. We will see what options I have available when the time for the swap comes along.
Old 07-09-2012, 08:42 PM   #9
clinebarger
This swap will be VERY time consuming, And you will be dealing with 300 volt current that the hybrid system uses, You need to be trained to work on this stuff.
Find a non-hybrid to do your swap...If you dont...You WILL wish you did.
clinebarger is offline   Reply With Quote
Old 07-09-2012, 08:46 PM   #10
Nothinghead
I am willing to bet when the time comes I will be doing a more traditional, basic, CHEAP swap. It's just a neat idea if I had the time and money.
