Old 05-19-2003, 02:03 PM   #1
Blue68
Blue68's Avatar
'68 C10 LWB for Sale.
Let's starting the asking price at $4000. Here is a list of what's been done, started, undone and bought.
More Pics here: http://home.attbi.com/~r.landrum/wsb...tos.html-.html
700r4 tranny installed
U.S. Radiator 4core
1998 Chevy 350 (Z-71 truck) w/Comp Cams Extreme 4x4 roller cam #08-411-8 (not radical at all), Edelbrock Vortec Performer intake, Edelbrock 1405 (600cfm) carb w/Electric choke topped off with a K&N Filter. Check out http://www.sallee-chevrolet.com/Che...me_4x4_350.html for a basis. New timing gear and chain and chrome cover too. The engine has not been rebuilt, just modded to run carbed. Serpentine setup.
Doug Thorley Tri-Y Headers.
1975 C-10 crossmember for Disc Brakes.
Vintage air, installed and removed. Compressor is gone, intended to use compressor on '98 engine.
Power steering.
Have windows, doors, front and rear glass rubber seals, felt, and runners.
Wheel vintique wheels (steel rally) 5 lug front 15x7 , 6 lug rear 15x8.
Carter electric fuel pump.
ACC Carpet (blue).
3 pt seat belts and center belt that work with....
'98 Chevy bench seat.
Oringinal bench seat, with new cover.
Spare Auto column out of unknow year chevy.
Kugel arm shift linkage so auto is shifted with original 3 in tree column.
Patch panels for inner/outer rockers, kick panel, and front pillar.
New chrome door sills.
Inside handle and cranks.
A/C dash controls.
Replaced core with oem core in good shape. With core mount hardware.
Replaced battery tray
Replaced Inner fenders
Poly graphite cab mounts.
Front sway bar from Early Classic.
There may be more, but these are the highlights that I can either think of or see on the truck. Thanks for your interest.
Todd.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
