Old 07-11-2012, 10:14 PM   #1
mooseknuckles
mooseknuckles's Avatar
4l80e shifting ?
has anyone had any problems with the 4l80e shifting?....for whatever the reason my trans will not stay in first gear for anymore the a few seconds...whenever I take off it goes the length of the truck or so and shifts into second gear. even when I try to manually shift it same thing...doing a burnout it shifts into second after a few turns of the tires...is it something in the tune?..the pcm was reflashed for 3:42 gears and 26" tires. I have the right gears now but my tires are 28".....it still as the stock van converter, and a TCI shift kit...and it shifts realy hard in all gears, even fourth.
mooseknuckles is offline   Reply With Quote
Old 07-12-2012, 12:00 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 4l80e shifting ?
I think it depends on the year and what operating system is on the ECM/PCM, the software may be able to adjust shift points. Talk to the person that tuned your ECM, see if they have any info about your tune.
Rich
1972 K5 Blazer CST Click HERE
Old 07-12-2012, 12:16 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
did you check the speed sensors if they were hooked up correctly, because mine did the same thing I had the connector swapped input speed signal was reading the output sensor and the output speed signal was reading the input senor
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-12-2012, 12:33 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
was there a wire in the connector wrong?
I've had o/d issues and I'm curious about the vss connection.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-12-2012, 02:17 PM   #5
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Moose:
- check out my other 4L80E thread
- what do you have for trans connectors on that harness
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-12-2012, 09:16 PM   #6
mooseknuckles
Originally Posted by Gordonr1973 View Post
Moose:
heres a pic with the connectors....I think every thing is hooked up properly, the wires aren't long enough to be switched around...
Old 07-12-2012, 10:17 PM   #7
clinebarger
That doesnt mean they are not switched, You have a untested aftermarket harness,
clinebarger is offline   Reply With Quote
Old 07-13-2012, 12:03 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^ would the pcm throw a code, or not even know they were switched?
Old 07-13-2012, 06:05 AM   #9
mooseknuckles
so now what do I do?.....I dont have anything to read the codes with....
Old 07-13-2012, 12:00 PM   #10
Gordonr1973
Home Built '87
look on kijiji for a obdi II code reader
maybe if you bought / borrowed a Superchips programmer you could use that to read codes with? -- I'm not sure about that one though
Can Tire had the OBDI II on sale last week up here, maybe down there they would still honor the sale price?
My new S&P harness has all the tranny connectors on it (there are at least two more from memory that connect to the black plastic module that your shift linkage will pass through into the transmission.)
I drove the truck last night through the gears, shifting was normal and I will get it out on the highway today to check shifting into O/D.
Will it shift into other gears normally after going to second?
I would check your brake switch by the column to see if your connections are correct for the TCC lock out / disengage (if that is the correct terminology) when the brake pedal is used.
Don't worry, for every problem there is a solution, we just haven't got there quite yet on this one!
Gordon
Old 07-13-2012, 12:01 PM   #11
Gordonr1973
Home Built '87
Is your spedometer reading anything when you drive?
Gordon
Old 07-13-2012, 12:42 PM   #12
mooseknuckles
speedo's not hooked up...I'm using a GPS for a speedo.....
Old 07-13-2012, 12:55 PM   #13
mooseknuckles
I'll have to check out canadian tire for that....I can manually shift 2-3 and 3-4, but I cant shift 1-2 manually because its already shifted by then.....as for the brake switch it seems to be working, when I hit the brakes you can feel the converter disenguage.... I'm sure someone knows the answer...just a matter of time...meanwhile I've been talking to Jon at PSI.....I'll let you know how thats going.......
Old 07-13-2012, 12:58 PM   #14
mooseknuckles
I'm not 100% sure what the mph is when its shifting (maybe 10mph) but, when I'm at a stop sign and drive off, its already shifted into second by the time I cross the street.....
Old 07-13-2012, 05:42 PM   #15
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
You need to get a scan tool...even if its just a $50 one that only reads and displays codes. I was using my Aeroforce Interceptor I had put in our TBSS a few years ago, just pulled it out for the truck. It reads codes as well as clearing them, plus a bunch of other stuff.
Since then I purchased HP Tuners....its a full on ECM/TCM scanner and editor. Wow....if your interested in performance and have efi........ you need something like this.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-13-2012, 07:10 PM   #16
clinebarger
Nope, The PCM wouldnt have a clue.
Old 07-13-2012, 07:53 PM   #17
mooseknuckles
so I should try switching them around??
Old 07-13-2012, 08:41 PM   #18
clinebarger
Yes, It wont hurt anything, & would atleast rule that out. Untape the harness if necessary, Dont pull on the plugs.
Old 07-13-2012, 08:56 PM   #19
mooseknuckles
ok...I'll give'r a try tomorrow...Jon@PSI wasn't very helpfull.
Old 07-14-2012, 06:30 PM   #20
mooseknuckles
well tried switching the plugs around on the tranny..didnt do nothin....
Old 07-14-2012, 09:11 PM   #21
clinebarger
Codes?
Old 07-14-2012, 09:59 PM   #22
mooseknuckles
I got nothing to read them with....been doing some reading over on performance trucks....looks like its in the tune, and has something to do with the shift kit...
Old 07-15-2012, 10:43 PM   #23
Mr. 250r
Mr. 250r's Avatar
can't you go to a local o reilys autozone etc and run the codes for free? that's what i did with my diesel most places are nice enough to do that
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 07-18-2012, 12:31 AM   #24
Gordonr1973
Home Built '87
No O'Reilley's up here :-)
But Canadian Tire might lend you a code reader b/c they have that 'lend a tool' program in their stores.
Wouldn't hurt to call. I was supposed to be in Ottawa for meetings this week but they got cancelled & moved to Toronto, otherwise I'd pop by to help you!
Gordon
Old 07-18-2012, 05:59 PM   #25
mooseknuckles
I'll def have to look into that gordo....Im almost 100% sure it needs a tune to fix it, because of the shift kit...and not too many places around to get it tuned at....so I've been looking at buying a HP tuner.....also have to check the voltage at the TPS.
