05-20-2003, 10:47 AM | #1 |
No longer truckless
2wd & 4wd bed different??
Is there a differnece in 2wd & 4wd beds? I haven't fully investigated it yet, but I bought a 2wd bed for my wife's 70 4X4 a long time ago. The body lnes don't seem to match up. The bed lines are slightly higher than the cab lines.
Could it just be worn out body mount bushings? The difference is somewhere between 1/4" to 1/2". |
05-20-2003, 10:52 AM | #2 |
Binder Rep
should just be worn out cab bushings.
05-20-2003, 10:59 AM | #3 |
No longer truckless
I know that on an 87 or so dodge there was a difference between the beds. I think the frames were different between 2 & 4wd versions cause there was a couple tabs on the 2wd version that prevented it from being able to sit flush with the frame.
I didn't recall there being any tabs on the chevy bed I put on, but that's been a year ago & I haven't crawled under there to look at it again. |
05-20-2003, 11:09 AM | #4 |
Resident Curmudgeon
The beds are 100% identical. Cab mounts for 1/2 ton 4x4's are different than 1/2 ton 2wd, but are identical to 3/4 ton 2wd.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
05-20-2003, 11:09 AM | #5 | |
Hot Damn - Here I Am!!
Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
05-20-2003, 11:13 AM | #6 |
No longer truckless
So from what CPNE said, what do I do to remedy the misalignment? The trucks a 1/2 ton 4X4. Do I just replace the bushings with the origianl style ones or get a 2wd version?
EDIT: I re-read it & I think you are just saying that the mon=unts are in different places. |
05-20-2003, 11:16 AM | #7 |
Resident Curmudgeon
replace your cab mounts (front and rear) with 3/4 ton 2wd cab mount kit. I did this on a 72 1/2 ton 4x4 and had zero problems with body lines as viewed with the naked eye.
