![]() Join Date: Jan 2012
Wanted: 69-72 Small Block AC/Pwr steering pulley and bracket set
Looking for the brackets and pulleys for 1969 through 1972 small blocks.
Specifically the power steering pump pulley and brackets, double groove crank pulley, double groove water pump pulley, single groove power steering crank pulley, upper and lower alternator brackets. These pulleys are for small blocks with air conditioning, but will work on ones without AC. Here's an example of what I'm looking for (These images were borrowed from another thread. I hope that's okay): |
![]() Join Date: Jul 2001
Re: Wanted: 69-72 Small Block AC/Pwr steering pulley and bracket set
Found this thread while doing a search. Did you ever get what you needed here? I have a couple of the pulleys you pictured if still needing them. LMK.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Hey Iron horse. I bought a pwr steering setup from another member but I noticed that some of my pulleys are different than the ones pictured above. I got the pulley on the pwr steering pump and the 3751232 BB one but I ended up with a 3874418BS GM instead of the 3850838 or the 399?646AH. Could you post or send me pics of what you have and how much you're asking for them? I'm still new to these trucks and I'm not exactly sure what I will need. My 70 C10 has a 1973 chevy 307 in it. No AC or power steering currently. Thanks.
I have a alternator/fan double pulley and the lower double crank pulley for a power steering setup. Don't recall the numbers from memory and don't have them pic'd in the computer. Am in the middle of a two day swap meet and both parts are on my booth table. Don't recall what I have them priced at, to many items to remember. Will bring them home tomorrow if they don't sell and get a couple pics and post the numbers.
I have a upper and lower alt bracket for 40.00 shipped, PM me your email and i will send you pics, Thanks-Matt
71 2wd k5 67 Nova |
Pics of the pulleys I have. Fan pulley is numbered 3900434 AB, crank pulley is numbered 3850838 BG, both of those are double pulleys. Also have a single crank pulley numbered 3751232 BB. Did not take pics but have 2 single groove crank pulleys, no number, 6 3/4" in diameter. Any of these what you are looking for?
I also have a set of A/C brackets for 75.00 shipped, Thanks-Matt
71 2wd k5 67 Nova |
cericd, posted pics and part numbers as requested, any interest? ??
Since no reply from cericd these pulleys are now available to anyone interested. Will post to a new thread to avoid confusuion.
#10 | |
Hey Ironhorse, sorry for the late response. I'm not that familiar with these trucks so I would have to do some research to see what pulleys I actually need. Like I said in the message below, I bought a setup from another member a while back and I could possible have what I need already but it doesn't match the set I had initialy seen posted. So, I was trying to get a little guidence form the knowledgable members here.
